Stock handlebar measurements
Try as I might, I can't seem to get an accurate measurement of the stock hanldebars while they're installed, and I sure as heck don't have time to disassemble the whole thing. Does anybody
A) know of someplace where this information can be looked up? I haven't found this information readily available on the net.
B) have a pair of stock handlebars sitting somewhere that could be measured for the Rise, width, pullback, and center width?
I too am interested in this info, wanting to put similar sized bars to replace the beach bars on my Speedmaster.
The closest I've got is Webike sells an aftermarket bar from Hurricane that is **supposed** to be stock dimensions, but i'm skeptical.
https://japan.webike.net/products/2074556.html
These are 5 3/4"h, 29"w, 6 7/8" pullback. That does look close to the inaccurate measurements i'm able to take on my installed handlebars.
I took some measurements to compare with the "Hurricane" bars, which were 30mm taller, but the same sweepback and width. The key in measurement is to have the top bar areas perfectly level.
I added a length measurement for that top bar area because if wider grips or heated grip controls/throttle lock were added, it may push the master cylinders into the curve, and the levers would tilt up.
I might add that Suzuki V-Strom 650 bars are very close overall.
This is perfect! thanks! i can finally get an accurate comparison.
So, to expand on this, I'm looking at these Bars as a replacement (even the tallest clip ons are too extreme of a change, as it turns out)
[Image: db55fd6376758eb5b3e91880183c2b1a.jpg]
These are about 5/8" forward, 1 3/4" lower, and approximately the same width. In the opinion of the experienced, are these too close to dirt tracker bars? because that is definitely not what i'm looking for.
(04-12-2022, 02:43 AM)misterprofessionality_imp Wrote: This is perfect! thanks! i can finally get an accurate comparison.
Dirt track bars are 3-4" tall sweep back farther, likely wider too, kinda like the bars on an old Schwinn or beach cruiser. Be sure they have long enough straight sections on the tops.
  Knocking noises; vibrations in the handlebar; oil sipping at valve lid gasket TheLegend 47 5,550 11-16-2025, 12:01 PM
Last Post: TheLegend
  Stock Cylinders dave 5 853 10-14-2025, 10:41 AM
  How much do stock pistons weigh? jikemenkins 4 636 04-28-2025, 10:06 PM
Last Post: Whoops
  CB1100 EX CA K handlebar switches sprint 7 590 02-25-2025, 10:36 PM
Last Post: sprint
  Handlebar: passage of cables pericleromano_imp 7 596 11-03-2021, 02:50 AM
Last Post: j3gq_imp
  Handlebar bolts torque value? (CB1100RS -18) Olof_imp 3 395 04-03-2021, 01:35 AM
  Handlebar clamps Buzzard Biker_imp 6 482 02-04-2020, 06:06 AM
Last Post: 2017EX_imp
  Handlebar Weights dave 9 608 01-29-2020, 02:11 AM
  Stock Suspension Adjustment riggies_imp 28 2,048 10-16-2019, 02:08 PM
Last Post: jdvalero_imp
  Handlebars - Back to Stock ishouldbuyatacotruck_imp 17 1,576 08-22-2019, 06:44 AM
Last Post: ishouldbuyatacotruck_imp
