Ebay radiator guard rattles...
So I put the inexpensive Brushed Aluminum Radiator Guard that says CB1100 on my bike and it rattles pretty bad over 4,000 rpm...
Anybody else have one and fixed this issue...?
If I can't, I'm going to just remove it...
I would say just a bit of double sided tape strategically placed would solve it, some kits come with a little.
(+1) Tev62.
Consider "higher heat" VHD tape.
If not, consider just dabbing a bit of high heat silicone-like goo on the corners of the guard to mechanically isolate the two surfaces. Then, Bob's yer uncle.
I may have the same guard on mine.
I have a roll of 5mm thick black foam sticky on one side which I stuck on the guard were it touched the rad to prevent it rubbing, it must also stop any vibes and rattles because I havn't heard any.
[url=https://postimg.cc/SYS7k0gs][Image: 7852aadc0e4f838b53e1614690bae14a.jpg]
I have the same type of radiator guard as Mixagon (see above pic) and I stuck a piece of old inner tube (from my kid's bicycle) between radiator guard and CB1100. Seems to do its job.
(06-03-2021, 05:58 AM)bioman_imp Wrote: I have the same type of radiator guard as Mixagon (see above pic) and I stuck a piece of old inner tube (from my kid's bicycle) between radiator guard and CB1100. Seems to do its job.
Excellent idea.
(06-03-2021, 03:26 AM)Mixagon_imp Wrote: I may have the same guard on mine.
Dang Mixagon... You probably have a thread on it someplace, but those are cool looking wheels.
^^yes they are^^ Thumbs Up
put some rubber washers in the mounting scheme
(06-03-2021, 02:11 AM)boynton6spd_imp Wrote: So I put the inexpensive Brushed Aluminum Radiator Guard that says CB1100 on my bike and it rattles pretty bad over 4,000 rpm...
[Image: 27da215e4d40f79b2ec838bfbf166431.jpg]
[Image: 60df489f900c64ac71b871b0132e3aba.jpg]
[Image: e7d3c02eeb157c5b4b93a2a7f035864f.jpg]
[Image: ba5198299cfd1ac2b40969a420bb05b8.jpg]
Hi, I have had great luck with items for my bikes from China. All the negative, mostly unwarranted, comments aside; the radiator screens work great. One of them needed a little holding down for awhile with a black zip-tie to get it going the direction needed.
But the photos show they work and only cost about $30/$40 each.
The holes/spaces on yours are too large where tiny rocks/debris could enter. I have had mine a couple years, and not even a moth can make it to heat my bike up!
And mine make no noise whatsoever!
  FOund on Ebay- pretty good price on a used shop manual PowerDubs_imp 0 237 03-24-2023, 06:39 AM
  Engine Guard Install Question? linuxology_imp 27 1,881 07-25-2020, 08:52 PM
  145$ for the set of rotors on ebay. mvk24_imp 37 2,895 06-26-2020, 10:11 AM
  Cam chain rattles when cold Speed_imp 24 1,610 05-28-2020, 05:41 AM
  "13 muffler guard HBFL_imp 2 329 04-16-2019, 08:06 AM
  SW Motech engine guard torque specs greekcb_imp 2 304 10-05-2017, 09:57 AM
Last Post: greekcb_imp
  chain guard, DLX Jim_imp 3 341 04-01-2016, 07:09 PM
Last Post: CB4ME_imp
  2013 Shop Manual on eBay kennyw 2 297 08-28-2015, 12:36 AM
Last Post: DGShannon_imp
  Chain Guard cbfan_imp 8 630 02-11-2014, 04:47 PM
Last Post: calamarichris_imp
  chain guard extension petec_imp 3 448 06-01-2013, 10:03 PM
Last Post: petec_imp
