Safety issue to watch out for.
I was just installing a new air filter on my 2014 STD and noticed the wire harness directly below the air clearer housing was being scrubbed by the swingarm and worn through.
After some investigating, I found that the harness stay that is located a few inches below the air cleaner housing had popped out of its bracket and was allowing the harness to relax against the side of the swingarm which, as you are aware is a moving part... If the wrong wire gets worn through and grounded, the engine could stop mid-turn, and that would certainly be bad.
Anyway, when you have the right side cover off, check your wire harness stay to make sure its still attached to the frame and that the harness running down from there isn't contacting the swingarm.
Good tip Joe.
Just checked mine and all is well.
That was a good find. There isn’t a lot of clearance between the swingarm and wire bundle.
Thanks Joe.
Thank you. I will be sure to take a look before I put my bike back on the road.
Thanks for the heads up Thumbs Up Thumbs Up
I'll be checking mine right away.
Thanks for the tip Joe.
I see you must like VFR Hondas. I have 111,000 miles on my 1998 VFR800, and it's the best bike I have ever owned. I have a 2002 VFR800 that I picked up on E-Bay that I am restoring - bought non-running, so we'll see what happens.
Yeah, I love the 90deg V-Fours, especially the ones with gear driven cams. I guess I fell in love with the relaxed seating position of the CB.
(08-20-2020, 12:16 PM)Dave_imp Wrote: Thanks for the tip Joe.
  Help from the hive mind: Intermittent Starter Issue (2017) JRD 10 521 01-30-2026, 02:16 PM
Last Post: JRD
  Shifting issue Cormanus 31 2,161 05-15-2024, 12:59 AM
  Arrow Slip on issue - stock gasket didn’t fit Ddawg1144_imp 4 456 02-21-2023, 07:51 AM
  Fuel reserve display issue Banksy_imp 2 283 06-29-2022, 04:37 AM
  Brake reservoir screw head issue satchit 72 5,292 04-24-2022, 11:55 PM
  Mechanical issue and hello again RickNRoll53_imp 8 677 12-16-2021, 06:46 AM
  CB 900C Custom Spark Issue goatman64_imp 3 361 11-27-2021, 07:11 AM
  2017 CB1100ex / Flat tire issue and save Senna02_imp 27 2,044 07-19-2021, 08:28 AM
  starting issue jigs_imp 12 799 06-06-2021, 01:51 PM
Last Post: max
  Neutral safety problem- boatdetective_imp 15 881 06-05-2021, 10:18 PM
