Threads: 1
I was attempting to hook up by battery tender to the battery but when I went to remove the battery cover the screw holding in place is stuck. Not sure if someone used thread locker or what as it seems a small screw but I have now succeeded in stripping it.
Since the battery cover itself is plastic, can I just the cut the plastic and basically remove it out around the screw? I think I would have better leverage on the screw without the plastic.
In addition is the cover necessary other than to hold the tool kit? Does the battery actually strap in beneath the plastic cover or does the cover help to hold the battery in place? On other bikes I've owned the battery is usually immediately accessible once the seat is removed. If thats the case I'll probably just cut the cover out for now and be done with it.
Thanks for any help.
Likes Received: 610 in 274 posts
Likes Given: 786
Been awhile since I was in there but that screw is a shouldered screw, and there is a push pin that has to be removed before box can come out. Technically the box does not hold the battery in, but would keep it from " bouncing up".
Likes Received: 591 in 324 posts
Likes Given: 996
Are you talking about a plastic blind reteiner ("pop" rivets) ??
No need to cut anything, just remove/unscrew its middle, then the outer clip = 5 sec job
https://www.youtube.com/watch?v=dWHSXsew6yU
Likes Given: 141
That screw sticks out from behind the fender and is exposed to whatever the wheel throws up. You can see it if you get down and look under the fender. It probably got corroded in.
Threads: 115
Make certain that you have a good fitting screw driver and hold the screw retainer in place with your left hand when you put the screw back in . I do not even bother with the plastic "rivet" type connector , no need for that one.
Threads: 1
No not the pop rivet, that works fine. It’s the screw itself that is stuck. I’ll have to see if I can twist from under the fender or if it’s corroded.
My cutting proposal is contingent on not being able to remove the screw.
Does anyone know the battery cover part # as well if I do cut?
Likes Given: 996
Likes Given: 141
Syrio, using JIS screwdrivers is always a good idea. Our bikes do not have Phillips head screws. Although most people do use Phillips drivers, they will cam out pretty easily and mess up screw heads. A nice little set of Vessel JIS screwdrivers should be in your future.
Threads: 1
(12-06-2020, 10:52 AM)Lord Popgun_imp Wrote: Syrio, using JIS screwdrivers is always a good idea. Our bikes do not have Phillips head screws. Although most people do use Phillips drivers, they will cam out pretty easily and mess up screw heads. A nice little set of Vessel JIS screwdrivers should be in your future.
Ah that is good to know. I did use a Philips head.
I had looked through that parts catalog but didn’t see the battery cover, will have to check again.
I’ll probably attempt to drill the screw out now that I know it just goes through the fender. I wasn’t sure what was on the opposite side.
Likes Given: 141
If you look, you will see a rectangular plate nut. There are 2 there. I forget right at the moment what the other is for.
Battery box is shown on the listing for the rear fender:
https://www.hondapartshouse.com/oemparts...ear-fender
The screw goes into one of the item 6 nuts. The screw goes through fender B, item 13. It is plastic.
