01-12-2018, 07:13 AM
Does anyone know the lower fork tube measurement in inches and or mm? I need to order some fittings to install some Denali lights I have left over from another project.
Thanks
Thanks
Outside lower fork tube diameter
Thanks
01-12-2018, 08:19 AM
(01-12-2018, 07:13 AM)Mscb1100_imp Wrote: Does anyone know the lower fork tube measurement in inches and or mm? I need to order some fittings to install some Denali lights I have left over from another project. Not sure where you're planning to mount the lights ... The section just below the mudguard mount and above disc rotor has room for bracket. It measures 2" OD.
01-12-2018, 08:31 AM
(01-12-2018, 08:19 AM)Aussieflyer_imp Wrote:(01-12-2018, 07:13 AM)Mscb1100_imp Wrote: Does anyone know the lower fork tube measurement in inches and or mm? I need to order some fittings to install some Denali lights I have left over from another project. Not sure where you're planning to mount the lights ... The section just below the mudguard mount and above disc rotor has room for bracket. It measures 2" OD. On the fork leg just below the fork seal No mudguard on US models that I know of on the forks Sent from my iPad using Tapatalk
01-12-2018, 08:49 AM
(01-12-2018, 08:31 AM)Mscb1100_imp Wrote:(01-12-2018, 08:19 AM)Aussieflyer_imp Wrote:(01-12-2018, 07:13 AM)Mscb1100_imp Wrote: Does anyone know the lower fork tube measurement in inches and or mm? I need to order some fittings to install some Denali lights I have left over from another project. Not sure where you're planning to mount the lights ... The section just below the mudguard mount and above disc rotor has room for bracket. It measures 2" OD. On the fork leg just below the fork seal No mudguard on US models that I know of on the forks Sent from my iPad using Tapatalk The widest OD of the fork lower, where the seal seats, is 62.9mm. The narrowest OD of the fork lower is 50.9mm. All models have lugs for a mudguard, perhaps it's a terminology thing. What do you call that half round metal thing over the top of the front wheel ... a fender?
01-12-2018, 09:01 AM
(01-12-2018, 08:49 AM)Aussieflyer_imp Wrote:(01-12-2018, 08:31 AM)Mscb1100_imp Wrote:(01-12-2018, 08:19 AM)Aussieflyer_imp Wrote:(01-12-2018, 07:13 AM)Mscb1100_imp Wrote: Does anyone know the lower fork tube measurement in inches and or mm? I need to order some fittings to install some Denali lights I have left over from another project. Not sure where you're planning to mount the lights ... The section just below the mudguard mount and above disc rotor has room for bracket. It measures 2" OD. On the fork leg just below the fork seal No mudguard on US models that I know of on the fender Sent from my iPad using Tapatalk The widest OD of the fork lower, where the seal seats, is 62.9mm. The narrowest OD of the fork lower is 50.9mm. All models have lugs for a mudguard, perhaps it's a terminology thing. What do you call that half round metal thing over the top of the front wheel ... a fender? In Mississippi that half round metal thing over both wheels is typically called and spelled “fenda” lol ![]() Seriously, thanks for the measurements. We call a rubba flap hangin frum the fenda a mudguard Aussieflyer Do you have a side view picture or your bike It has an interesting paint scheme
01-12-2018, 10:34 AM
MSCB you're welcome.
There are a few pics in this post: [url=http://cb1100forum.com/forum/showthread.php?tid=1974&page=6]http://cb1100forum.com/forum/showthread....974&page=6 |
« Next Oldest | Next Newest »
| CB1100ex Tires pressure, when changed tube to tubeless | tory_imp | 10 | 918 |
10-09-2023, 07:51 AM Last Post: Cormanus |
| Rear axle diameter 2014 vs 2017 | ashishNJ_imp | 4 | 546 |
08-28-2023, 06:07 PM Last Post: dopaytoplay_imp |
| 2017 tube type tires | Mafd2_imp | 4 | 499 |
02-08-2023, 01:10 PM Last Post: Cormanus |
| Fork tube rust | melfl_imp | 8 | 788 |
12-23-2022, 04:41 AM Last Post: redbirds_imp |
| Fork Tube hex head bolt tool fitment ? | bflint | 8 | 757 |
11-30-2020, 06:24 PM Last Post: jtopiso_imp |
| fork overhaul vs. fork replacement? | misterprofessionality | 20 | 1,824 |
09-20-2020, 07:13 PM Last Post: DBM_imp |
| Lower engine knock | airenping_imp | 33 | 2,398 |
09-20-2020, 12:19 PM Last Post: Cormanus |
| Fuel Tank overflow drain tube. | zirconxi_imp | 11 | 950 |
05-29-2020, 11:36 AM Last Post: LakeWylieJoe_imp |
| Throttle tube easy to fit? | Buzzard Biker_imp | 9 | 706 |
02-28-2020, 11:21 PM Last Post: Bazbro_imp |
| Lower suspension | apehair_imp | 3 | 387 |
08-26-2019, 11:51 AM Last Post: GoldOxide_imp |
