New exhaust installed
Installed the new Moriwaki exhaust today. I used new Honda copper gaskets and the gasket/sealer that Moriwaki provided and coated the gaskets with it. I have all the pieces in the right place but it is not fully sealing. So, it’s obviously excessively noisy where the exhaust is connected to the engine/cylinders. Do I need to heat up the exhaust before I torque down the bolts to get a good seal or is there something I am missing, I bought three sets of gaskets in case something like this happened. I can add a short video with sound tomorrow. Thanks for the advice in advance. This forum has been immensely helpful.
I am am going to loosen everything up and pull the gaskets to see how they look. I have a feeling one side is more pinched than the other on each gasket as I had some difficulty getting the headers to properly connect to the exhaust. The exhaust has a header and muffler that all connect at one point and getting everything to fit caused some pinching and therefore leaking from the gaskets. I could barely get the nuts to screw on to the bots as the collars are pretty thick. So, I can’t see two gaskets fitting. I will look at getting a good coating of liquid gaske5 on each copper gasket as well.
i had to tighen mine while it was still hot with my aftermarket header and new gaskets
I am definitely going to get the pipes mildly hot before I tighten the header. I also read some other articles about cleaning the exhaust ports with a copper/brass brush and white vinegar to clean up the mating surfaces. I mounted an exhaust on a 1982 Kawasaki 440 LTD years ago and it seemed so simple, I should have done mire research before I started this one. I have been doing car and motorcycle maintenance for over 30 years and I can usually figure out stuff on the fly. This was not the case here. So, I have learned a lesson even in my 50’s.
Well, I am F’d. Exhaust is not sealing because prior owner who installed Delkevic exhaust, which was leaking badly from exhaust ports never took out the original copper gaskets. Gaskets came out when I took the Delkevic exhaust off and I didn’t notice the other set of embedded gaskets it until I went back to clean everything up in hopes of getting a better seal. They copper is embedded deep and is preventing the new exhaust from properly seating with a new gasket because the header won’t go far enough into each port. Getting that old gasket out is beyond my skill set and I am wiped out haven’t spent about 16 hours dealing with it. On top of that, the Moriwaki exhaust isn’t fitting perfectly either and the headers probably need to be heated to bend them a bit to fit into the exhaust. I don’t have any experience with a torch or bending pipes either and I am not interested in learning, Does any body know a good exhaust shop that can help in Orange County, California? I don’t necessarily need a motorcycle mechanic as this is purely an exhaust issue. I will do some searching on my own as well. Thanks for listening. I am done buying used bike ever again unless it is a restoration project. This one has been a bit of a lemon. I didn’t learn that the front brake rotors were friend until I ride it home for 500 miles. Those weren’t cheap either, The Delkevic exhaust was installed poorly and was leaking fumes pretty badly. There were a couple of other minor issues too. The $6,750 price seemed good at the time and it also has a power commander. It does run well but I have spent far more on it than I originally expected. I am still going to keep it though.
That does sound like a bit of a downer bvictory. Undecided
The worse I had was a used bike with a broken connecting rod, but overall purchasing used bikes has been a good experience.
(07-19-2023, 12:43 PM)m in sc_imp Wrote: that sucks. i hate prior hacks. this is why i either buy new, or a basket case where i have to do everything. dont get too exited and just slowly work on the exhaust gaskets one at a time, they will come out eventually. try a spring hook tool to snag one and start working it out.
I like the idea m in sc. I tried to envision the same approach, and with no learning involved. Smile
Just patience, persistence and brute effort.
Okay, there might be a few beers involved, and some old school radio playing off to the side.
Hello Bvictory, I feel your pain. Before bending your exhaust pipes have you verified that nothing else on the frame is bend, or misaligned?
Try Dr John's Motorcycle Frame Straightening, located in Anaheim, Ca. 714-630-4075. They unbent some wheels for me several years ago, and the results were excellent. I assume they're still in business. When I dropped my wheels off his shop was loaded with all sorts of repairs he was working on, most of them off-road quads and side-by-sides.
Good luck, and please let us know how it works out for you.
mine were also smashed in i used a pair of snips to grab and twist and they come right out dont be scared theyll come out
(07-20-2023, 04:42 AM)1973cb750_imp Wrote: mine were also smashed in i used a pair of snips to grab and twist and they come right out dont be scared theyll come out
Snips are too big for these. I didn’t even see they were smashed in there until I cleaned the ports with a brass brush. I ordered some picks and hooks to help. Thanks for the encouragement.
  Can a 2013 centerstand be installed on a 2014? WRXer_imp 1 259 11-19-2023, 04:24 AM
Last Post: WRXer_imp
  Has anyone installed a power commander in? Doug Shepard_imp 3 494 08-10-2023, 07:20 AM
  Installed Yoshimura RSCV full exhaust today ManInBlack_imp 14 870 08-03-2017, 01:36 PM
Last Post: ManInBlack_imp
  Anyone installed the Hepco side carriers? ryanschillinger_imp 11 791 10-24-2016, 03:34 PM
Last Post: ryanschillinger_imp
  Backoff XP Installed Ulvetanna_imp 0 175 06-22-2016, 02:00 AM
Last Post: Ulvetanna_imp
  New O2 sensor installed Guth_imp 13 939 09-27-2015, 11:54 PM
Last Post: Toddman_imp
