Tire Balancing
For you guys that change your own tires, you know they have to be balanced again. I change my own tires and this way of balancing would make life a lot easier, but I don't know a lot about it. What do some of you tire changers think? http://checkeredflagtirebalancebeads.com/
I used balance beads on my Goldwing. Ran the tires for over 10,000 miles no problems at all. Will do it again if necessary.Thumbs Up
Kevin
http://www.marcparnes.com/
I own a Marc Parnes balancer. Simple, compact, accurate.
Personalty, I would trust the beads.
I used the beads one time. I had very poor results. When I decided to replace the tires, I found the beads were all static charged and were very hard to get off the rims so not to contaminate the new tire. I cannot see how they would ever freely move around in the tire if they were evenly distributed over the rim and inside the tire when I took it off. They acted like Styrofoam beads. I still find them in my garage at times.
I have been using DynaBeads on my 2001 Triumph Bonneville Tube Type wheels since 2008 and am quite happy with the tire wear pattern observed so far. Below is the link:
http://www.innovativebalancing.com/
  Bead method of balancing tires, does it work? MagnaRider 3 434 01-06-2025, 03:03 AM
Last Post: MagnaRider
  Tire replacement - Not a "Tire Thread" SportsterDoc 12 967 07-18-2018, 06:50 AM
Last Post: SportsterDoc
