headlight adjustment
Do any of you guys have any tips for checking headlight adjustment? I installed a Dart flyscreen today(a Christmas gift from my wife!), and I'm not sure that I got the headlight back into the stock position. Any assistance will be greatly appreciated.
Pull your bike in front of the garage wall and draw a horizontal line at the wall where the light line is.
Draw a parallel line 5 cm (2") below that line at the wall.
Pull the bike 5 m (~17 ft) back from the wall. The light line should now be at that parallel line at the wall. Move your light up or down until it fits.
Thanks, Django!
Mike throw your allen in your tank bag/pocket whatever. Go out to a dark, flat road and stop in the middle of the road. Sit on the bike and flip on the high beam. Is it set so you can see the furthest down the road? or is it shining 30 feet in front of the bike? or is it shining in the trees? Set it so you can see best furthest down the road, and tighten it up. When you need light, you need high beam and it will be a different set up for every weight rider, what tires they have what suspension adj they have. Adjust it to fit your situation not the everybody situation.
Sounds good, Ferret. Thanks for the help!
The factory setting on my headlight bucket was ridiculously low. Basically, there was a horizontal line about 20 ft. in front of the bike where the light abruptly stopped.
I used the same method as Ferret and it made a huge difference.
  CB1100 valve adjustment purposely made rough ? bflint 7 577 01-20-2026, 02:19 PM
Last Post: MagnaRider
  Is balance shaft adjustment normal maintenance? ohiorider_imp 6 673 09-23-2019, 12:27 AM
  2017 CB1100 EX Headlight omarj_imp 19 1,391 03-19-2019, 09:28 AM
Last Post: DBM_imp
  Quick question about chain adjustment ohiorider_imp 14 1,022 11-03-2017, 09:14 AM
Last Post: Django
  Clutch and Brake Lever Adjustment retroman_imp 6 558 06-18-2017, 12:53 PM
Last Post: NightRider_imp
  Headlight vibration rattle tomas_imp 9 639 09-21-2016, 08:30 PM
  LED headlight regularworkingdad_imp 5 433 07-01-2016, 10:10 AM
Last Post: olekzap_imp
  Yellow Headlight Matt F._imp 44 2,812 04-20-2016, 12:15 AM
Last Post: LoneWoof_imp
  chain adjustment Southwend 11 750 04-10-2016, 03:39 PM
Last Post: Retsel_imp
  Headlight brightness rob_imp 18 945 12-16-2015, 02:23 AM
Last Post: Elipten_imp
