Is balance shaft adjustment normal maintenance?
I don't have a maintenance schedule in front of me. Just wondering if there is a factory recommendation that specifies at what mileage to check and adjust the balance shaft lash?
Thanks,
Bob
Bob, my Honda Service Manual 2013-2014 does not specify when it should be adjusted as per p. 3-4 & 3-5/Maintenance Schedule.
Also, chapter Crankshaft/Transmission/Balancer - Backlash Adjustment - no word of service intervals as per p. 11-38, it just outlines adjustment procedure.... it says
* if gear produces excessive whine noise, the backlash is too small
* if ..................................rattling...............................excessive
Video clip for your convenience starts from 2.06 min
https://www.youtube.com/watch?v=mEgQmyknW_4
Hope this helps.
Smile
I can't see anything on the maintenance schedule in the owner's manual.
The service manual tells you how to do it, but not how often.
Thanks, guys.
Bob
(09-22-2019, 10:55 AM)peterbaron_imp Wrote: Bob, my Honda Service Manual 2013-2014 does not specify when it should be adjusted as per p. 3-4 & 3-5/Maintenance Schedule.
Hope this helps.
Smile
Thumbs Up
Hope this helps.
Smile
Thumbs Up
Thumbs Up Thanks, GOx
Bob
So as long as you are NOT hearing that chuffing part at 2:31-2:32 in the video, no need to mess with the adjustment? I have not adjusted mine in 47,000 miles.
  CB1100 valve adjustment purposely made rough ? bflint 7 587 01-20-2026, 02:19 PM
Last Post: MagnaRider
  CB1100 prices - returning to normal? Gone in 60 26 2,009 11-30-2023, 12:56 PM
  BMW makes a Maintenance Free Chain cbolling_imp 31 2,215 08-31-2020, 06:22 AM
  Balance shaft - is it time to adjust? And valve check question ohiorider_imp 9 674 06-23-2019, 06:04 AM
Last Post: ohiorider_imp
  Quick question about chain adjustment ohiorider_imp 14 1,101 11-03-2017, 09:14 AM
Last Post: Django
  Clutch and Brake Lever Adjustment retroman_imp 6 566 06-18-2017, 12:53 PM
Last Post: NightRider_imp
  Head oil seepage normal? PowerDubs_imp 20 1,187 10-12-2016, 11:23 AM
Last Post: 736cc_imp
  Maintenance Records... quietguy_imp 33 1,870 09-02-2016, 06:48 AM
Last Post: Riko_imp
  chain adjustment Southwend 11 780 04-10-2016, 03:39 PM
Last Post: Retsel_imp
  Is this normal? CB360T_imp 48 3,083 03-06-2016, 06:44 PM
Last Post: capttwb136_imp
