Quick question about chain adjustment
The CB1100 manual shows the chain slack being checked on the lower run about 6-7 links in front of the rear sprocket teeth. Since I don't really know where the front sprocket is located (so I can determine the center of the lower chain,) does that seem like a good spot to check the chain slack? Difficult to describe without an illustration.
I want to get the chain adjustment as close to spec as possible, since many on here have told me that the 'clunking' I sometimes experience on downshifts, or simply backing off the throttle regardless of gear, may be in part due to a too-loose chain.
But at the same time, I don't want to destroy a good chain by running it too tight.
My chain doesn't feel all that loose, but when I measure the slack, I'm showing approx 2". That's measured by pushing the lower run down as far as it will go, and then pushing it upward as far as it will go.
If I push up on the lower run closer to the counter shaft sprocket, the chain can be pushed into the swing arm.
I'm not trying to overthink this, but I would like to eliminate some of the drive line clunk without going too tight on the chain.
I think spec is 1 1/4” slack. I would adjust it. The round thing on the front sprocket cover is directly over the front sprocket. Use that as a reference to locate the approx mid point of the chain.
(10-26-2017, 12:02 PM)chync_imp Wrote: I think spec is 1 1/4” slack. I would adjust it. The round thing on the front sprocket cover is directly over the front sprocket. Use that as a reference to locate the approx mid point of the chain.
Thanks for that piece of info. I'll use that as a reference point.
Bob
Seat of the bike and a other person controll it
Mine had a lot of "clunk" but to it also. But all of went away when I cleaned and oiled the chain good.
The "clunk" you may hear shifting down into first gear is normal and comes from the transmission design I believe. I saw a great explanation of that somewhere but I can't remember where. Shifting down into 2nd through 5th (on a 6 speed) on mine has always been very smooth.
I did adjust it before putting in a hundred lovely miles today. The weather looks like it's going to fall apart tomorrow, so today was a real gift.
And the CB feels much better. Much less clunking in the drive line. I checked it at 5-6 different chain positions, and I had between 1" and 1.25" slack after the adjustment.
I used the Motion Pro chain alignment tool that's been gathering dust ever since I sold my Bonneville T100 several years ago. I wanted to remove the chain guard so I could attach the tool, so I removed the two bolts I could see. There is apparently a third bolt holding the guard that is well-hidden on the side toward the wheel. Fortunately, removing the two outer bolts allowed me to swing the chain guard upward, giving more than enough room to use the alignment tool. The tool provides an additional level of confidence that the sprocket and chain are in alignment.
[url=https://www.google.com/search?q=motion+pro+chain+alignment+tool&rlz=1C1CHBD_enUS714US743&oq=pro+motion+chain&aqs=chrome.4.0j69i57j0l4.8414j0j8&sourceid=chrome&ie=UTF-8]https://www.google.com/search?q=motion+p...e&ie=UTF-8
Thanks to all for their advice.
Bob
Bob
That third mounting point is just a tab and slot towards the front of the guard. It will come out with a little wiggle while pulling up.
Bob
Good info. I'll be buying a shop manual over the winter.
Bob
Don't over think it. it's just a chain.
  CB1100 valve adjustment purposely made rough ? bflint 7 586 01-20-2026, 02:19 PM
Last Post: MagnaRider
  Helmets, the good, the quick and the ugly j3gq_imp 9 701 10-08-2021, 11:19 PM
Last Post: j3gq_imp
  Is balance shaft adjustment normal maintenance? ohiorider_imp 6 699 09-23-2019, 12:27 AM
  That was quick Foxcroft007_imp 14 919 10-29-2018, 07:18 PM
Last Post: Guth_imp
  Clutch and Brake Lever Adjustment retroman_imp 6 564 06-18-2017, 12:53 PM
Last Post: NightRider_imp
  chain adjustment Southwend 11 756 04-10-2016, 03:39 PM
Last Post: Retsel_imp
  headlight adjustment MikeD_imp 5 408 01-02-2016, 01:16 PM
Last Post: flynrider
  Suspension adjustment air charlie_imp 8 652 10-18-2015, 10:44 PM
Last Post: Brookland27_imp
  Shock Preload adjustment air charlie_imp 24 1,585 05-25-2015, 02:33 PM
Last Post: Ghis_imp
