chain adjustment
can't locate the manual.
2 quick questions,
1. adjust chain on centerstand or kick stand?
2. adjust to what degree of slack?
Thanks in advance
Center stand.
ferret posted a "how to" on chain adjustment.
http://www.cb1100forum.com/forum/showthr...p?tid=7158
Center stand.
There is a how to on this. Look for Ferret's How To for the 600 mile check.
I think too, its on the sticker on the swingarm.
OK, Curly posted just as I did...
Thanks
But to answer your questions with two quick answers.
1. Centrestand
2. 25-35mm
And ... in my opinion, it's better at the tighter end of spec.
(04-07-2016, 08:27 AM)Cormanus_imp Wrote: And ... in my opinion, it's better at the tighter end of spec.
Not sure what you mean by better but for me I like the chains loose. You have to account for suspension compression to calculate the true play in the chain. For a big dude like me I compress the suspension alot so a tight chain puts a lot of stress on the driveline components.
My experience has been that the gearbox feels a great deal smoother when the chain is at the tighter end of spec. It gets clunkier as it loosens. I'm a smaller dude so I go for tighter.
(04-09-2016, 03:16 PM)Cormanus_imp Wrote: My experience has been that the gearbox feels a great deal smoother when the chain is at the tighter end of spec. It gets clunkier as it loosens. I'm a smaller dude so I go for tighter.
I find this as well. No roll-on roll-off clunks, no banging into gear from neutral and no hard shifts. I've always kept mine at the tighter end of the spec.
I bet you do! lol
  CB1100 valve adjustment purposely made rough ? bflint 7 564 01-20-2026, 02:19 PM
Last Post: MagnaRider
  Is balance shaft adjustment normal maintenance? ohiorider_imp 6 670 09-23-2019, 12:27 AM
  Quick question about chain adjustment ohiorider_imp 14 1,018 11-03-2017, 09:14 AM
Last Post: Django
  Clutch and Brake Lever Adjustment retroman_imp 6 552 06-18-2017, 12:53 PM
Last Post: NightRider_imp
  headlight adjustment MikeD_imp 5 380 01-02-2016, 01:16 PM
Last Post: flynrider
  Suspension adjustment air charlie_imp 8 629 10-18-2015, 10:44 PM
Last Post: Brookland27_imp
  Shock Preload adjustment air charlie_imp 24 1,483 05-25-2015, 02:33 PM
Last Post: Ghis_imp
