  • 1 Vote(s) - 4 Average
Anyone hollowed out stock catalytic converter?
Wondering if anyone here has gutted the stock cat on these bikes. Just about to start my little winter project and want to remove the exhaust and hollow out the catalytic converter to get some more sound. Not looking really for performance upgrades, just a bit more noise. I have the o2 sensor delete and PAIR deleted so the cat really isn't doing anything for the bike performance wise as far as I understand. But if I take the exhaust off to give it a full polish might as well gut the cat. Is it a honeycomb style cat? Can I just drill it out/ram a rod up there to clear it? Will I even gain any sound? Just curious on anyone's thoughts
I do not have emission testing where I am at and it's not a concern at all so, please don't give that suggestion lol.
Otherwise, all I have for getting ready for this spring is new tires and oil change.
Or, if anyone is selling an aftermarket exhaust, this guy is interested.  Wink
Thanks, as always!
'84 Honda Magna VF700 (Gone, but not forgotten)
'06 Yamaha VStar Classic 1100
'14 Honda CB1100 Std
its stainless steel mesh with platinum and super hard to do needs to be cut apart and tig welded the delkavic no cat header and a ecu flash is the way to go
2014 Cb1100 STANDARD #2061  ECU flashing.    Biker        https://www.facebook.com/cj.h.pfeiffer
(02-10-2026, 08:44 AM)1973cb750 Wrote: its stainless steel mesh with platinum and super hard to do needs to be cut apart and tig welded the delkavic no cat header and a ecu flash is the way to go
Is anyone still doing ECU flashes?
Posts: 2,500(0.57 per day | 0.79 percent of total posts)
Registration Date: 04-26-2013, 09:56 PM
I do if anyone is looking send me a email i got set ups for 13 14 and 17 model bikes 17 will be ignition and limiters only i dont have a fuel map for a 17 they use a different unit of measurument for the fuel cells that dont translate from the 13 and 14 map
1973cb750 does a flash that really wakes the motor up... he did mine last summer and it is everything it was before with a little more get-up-and-go... I got my O2 bypass a couple days ago and my Delkevic is hopefully getting ordered next week... along with opening up the flow I think a Delkevic system is like 20-25 lbs lighter than stock Smile
Looking forward to springtime!
2014 CB1100
ECU Flash
Delkevic Exhaust System
Ikon Shocks
Race Tech Gold Valve Emulator
SF Riding Fork Brace
Bridgestone Battlax T32 FR/RR
NOCO LiFePO4 Battery
  Stock Cylinders dave 5 909 10-14-2025, 10:41 AM
  How much do stock pistons weigh? jikemenkins 4 682 04-28-2025, 10:06 PM
Last Post: Whoops
  Stock handlebar measurements misterprofessionality 5 570 04-12-2022, 05:47 AM
  Stock Suspension Adjustment riggies_imp 28 2,328 10-16-2019, 02:08 PM
Last Post: jdvalero_imp
  Handlebars - Back to Stock ishouldbuyatacotruck_imp 17 1,664 08-22-2019, 06:44 AM
Last Post: ishouldbuyatacotruck_imp
  Catalytic converter back pressure? ChipBeck_imp 13 1,012 05-26-2019, 01:42 AM
Last Post: HondaJon_imp
  stock tool kit (if you can call it that) 12cb96vfr_imp 11 1,006 02-09-2019, 02:28 AM
  Stock header weight PowerDubs_imp 6 543 08-25-2018, 09:56 AM
  Back to Stock Muffler beardyweirdy@me.com_imp 14 994 06-18-2018, 11:27 AM
  Removing Cat Converter HBFL_imp 1 223 09-24-2016, 12:56 PM
Last Post: Ben70_imp
