2014 CB1100 alternator output
I haven't run across this figure. Can someone here supply me with the alternator output (preferably in Watts) though amps is fine. too. And perhaps at what rpm the alternator produces rated power?
Thanks,
Bob
From the 2014 factory manual, 0.336 kw @ 5,000 rpm.
(10-25-2018, 11:58 PM)Rocky_imp Wrote: From the 2014 factory manual, 0.336 kw @ 5,000 rpm.
336 watts / 14.2 volts = 23.66 amps
That seems low on the basis of pre-EFI Sportsters are 22 amp systems and EFI models are 32 amp systems.
CB alternator output capacity is rated at 336W/5000rpm...so Rocky is right, as well as SD with his conversion to 23.6A@14.2V...Smile+Smile=Big Grin
Cool
What do you reckon the bike uses of that 23.6 amps?
(10-26-2018, 01:15 PM)el duque_imp Wrote: What do you reckon the bike uses of that 23.6 amps?
Thanks to all of you for your responses. That's roughly what my 2003 Bonneville produced, and 15 - 20% more than my old Beemer system puts out. Just wanted to know for when I install heated grips and possibly run a heated vest at the same time.
The unknown is ....... how much does the fuel injection system/fuel pump use? Other things, like headlight and running lights, are easy to calculate. I think low beam is 55W. Just have to add up the rest of the bulbs.
I think I'm good running a relatively low-wattage vest and heated grip system, at least once I'm moving down the highway. I've gotten by with that setup for years with the 280W output of the R100GS system.
Bob
I recall reading a recent discussion of output/heated gear etc. but can't find it.
After reading it I figured my jacket liner and glove liners used all of the available extra. I use them sparingly deferring to the jacket first.
I have a Gerbing heated jacket liner and love it , do not buy their controller , there are easier ones to use than theirs.
  2014 CB1100 Standard Tires Scatchman_imp 28 1,807 03-07-2026, 05:54 AM
  Buying 2014 CB1100 and have questions MagnaRider 31 2,930 09-06-2024, 05:24 AM
  2014 CB1100 with only 5 gears hawary_imp 21 1,379 06-09-2022, 09:16 PM
  Venting RE: 2014 CB1100 bvictory_imp 23 1,732 05-24-2021, 01:26 AM
  SlipOn Exhaust For 2014 CB1100 Deluxe Honda4Ed_imp 20 1,400 04-24-2021, 07:51 AM
Last Post: michael1954
  2014 CB1100 dlx price? NickLHG_imp 23 2,084 12-31-2019, 12:26 AM
  2014 CB1100 Salvage title Honda_Fan_imp 38 2,427 01-29-2019, 02:28 PM
Last Post: rboe
  2014 CB1100 Std vs 2017 CB1100 ?? ohiorider_imp 14 1,275 12-22-2018, 10:49 AM
  2014 CB1100 standard & sundry items SportsterDoc 22 1,477 09-11-2018, 10:42 AM
  cb1100 2014 New in Box jitaylor_imp 51 3,660 06-13-2018, 01:05 PM
Last Post: Chrisvillar98_imp
