Venting RE: 2014 CB1100
So, I finally found a 2014 CB1100 in Phoenix Arizona for $6,500 The pictures and the description looked fine. So, I flew in from California on Tuesday and went to pick up the bike. That's when the "not so fun" experience started.
The bike had 8,100 miles and it did look like it was garaged for its whole life but the previous owner did not treat it well. The tank had all kinds of swirls and minor scratches that I think I can buff out. The PUIG windscreen was yellowed with many many scratches and the oil was low. The exhaust was yellowed severely. The dealer added some oil and I took off on the bike to my hotel. As I was riding to my hotel, I felt the throttle grip spinning around the throttle tube. I couldn't get full power out of the bike and felt uneasy. As soon as I got to my hotel. I pulled on the Oxford throttle grip and it slid right off! Strike two for this dealer. I did some research and got some Gorilla glue and reglued it and that seemed to fix it.
So, I head out at 5 in the morning to ride 400 miles back to California. The initial couple hundred miles felt good but I was noticed that the fuel gauge was flashing at me when I had just over a gallon of fuel remaining (haven't read the manual yet but I guess this is how it works on this bike). I had major range anxiety at first because I was riding through the desert where gas stations were about 35 miles apart. I finally got used to the fuel gauge and moved on. However, I also noticed a lot of vibration when I applied the front brake at speeds over 45 mph. Don't know if it's the discs or the pads.
About the last one hundred miles the bike started feeling a little sluggish and it didn't seem like a fueling issue. I made it home safely and got on the ground to look at the chain. Upon inspection the center stand was rubbing against the chain. The bump stop on the Delkevic exhaust had rotated enough to eliminate the gap between the chain and center stand. It must have been doing it for a while because the chain cut a 1/4-inch groove in the center stand. So, the chain could have broken at any time and killed me.
So, the bike is home and safe now and I have a lot of work to do. I need to get a new chain, new sprockets, new brake pads, oil change, brake fluid flush, tightening of exhaust clamps, checking torque values on every nut and bolt, and a full detail. I am going to try the tinfoil and vinegar solution to clean the yellowing exhaust cleaned. I welcome any suggestions on any additional checks I should jump on.
The bike was very fun to ride and I am still really glad I purchased it. However, that was too much excitement for my 55-year-old body and I think I used one of my nine lives on the ride.
Thanks for letting me vent.
Hello howdy and welcome to the forum.
Dang, that's a heck of a start with a new to you bike. Hope you get it all sorted out and have no more drama going forward
Glad you made it OK! Try not to let the bumpy start cloud your perception, this really is a drama free machine when reasonably cared for. Welcome!
Ben
Sorry about your uneasy introduction to the CB1100. If I read your message correctly, it seems the aftermarket parts on your bike caused you the most grief (it’s not clear if the brake pads are OE or not. I’m guessing they’re not). The bike itself should be very reliable — it’s well engineered and assembled. So much for aftermarket mods!
Yikes. Indeed that is much drama.
Glad you can write about it bvic, and may your future excursions be far more pleasurable and rewarding.
If this is recent I think I might of seen the listing.
Firstly, it's a used bike. Expect some minor stuff like your centerstand issue. Easy fix though. Just get a Yoshimura stopper.
The fueling thing thing can be a vacuum hose. If the bike is a desert bike there's a change you can have a vacuum hose off or even dry rotted. I'll be sorting out mine soon.
These bikes are VERY solid , overengineered and purposely way underpowered for more reliability. 80hp and like 65-70 lf lbs. A tune, open airbox and full decat exhaust and you're over 100 at the wheel and 75-80 ft lbs. And still plenty left.
Bottom line you may have some petty issues from the fault of a past owner. Sort it out and you'll love this thing. I bought mine with 14k and had some small issues. After sorting it out I have a pretty little beast.
(05-20-2021, 08:28 AM)bvictory_imp Wrote: So, I finally found a 2014 CB1100 in Phoenix Arizona for $6,500 The pictures and the description looked fine. So, I flew in from California on Tuesday and went to pick up the bike. That's when the "not so fun" experience started.
I have one for sale that is an awesome ride and ready to ride!
https://corpuschristi.craigslist.org/mcy...48183.html
Think you have the right approach and a chance to feel good about your work afterwards.
About the sluggish last bit of the ride, i would check if the brakes are dragging before you do anything to them, you may find an issue, both wheels should rotate freely and without any noise of the disks, if there is a noise it still could be corrosion/sediment on the disks, the pulsing in the front tire points to such a situation so after all those years with the condition it's in that could be a concern, these bikes are very good but they don't like a salty/ moist environment.
If all is working ok the brake systems should be ready for a flush and that would show up any issues with stuck pistons and master cylinders etc., i would clean the pistons with brake cleaner and a brush before compressing them to expel the maximum amount of fluid that can be replaced and thereby checking free and equal movement of the pistons ( They do have different diameters ).
Maybe have a look inside the fuel tank to see if there are things in there that shouldn't be, if there was ethanol stored in the tank for an extended period which we have had a case of recently.
Most bikes have a stainless exhaust ( 4 into 1 ) and the pipes are normally yellow and shiny if looked after, they clean up well with autosol polish and 1600 grit wet and dry if the dirt is a bit stubborn, chrome systems are 4 into 2 dampers and you may want to be careful with the chrome, it may not be a heavy coating, try a small area out of sight first to see if the method works.
Also inspect the tires for any defects, you get the idea, it's like a pilot's pre-flight check, good to hear the story and to have you on the forum.
Welcome, and sorry to hear about your unhappy experience. That hardened chain will saw through the frame and engine before it breaks from wear on the edges of the plates. The edges may have lost its coloring, but I doubt it has any measurable wear, or any weakening. Or any resulting damage to the sprocket. I would happily put that chain and sprocket on my bike.
I once rode a GL1800 from Nevada to LA, and noticed late in the ride the fuel gauge needle was dropping quickly and the bike was feeling sluggish. When I stopped, I realized I had been riding into a heavy headwind.
bvictory, welcome to the forum. Not such an auspicious start, but I'm sure you'll get it all sorted soon and will then be able to enjoy the bike. I understand you won't be at all impressed with the dealer whose pre-sale checks leave a great deal to be desired.
  2014 CB1100 Standard Tires Scatchman_imp 28 1,795 03-07-2026, 05:54 AM
  Buying 2014 CB1100 and have questions MagnaRider 31 2,881 09-06-2024, 05:24 AM
  2014 CB1100 with only 5 gears hawary_imp 21 1,357 06-09-2022, 09:16 PM
  SlipOn Exhaust For 2014 CB1100 Deluxe Honda4Ed_imp 20 1,397 04-24-2021, 07:51 AM
Last Post: michael1954
  2014 CB1100 dlx price? NickLHG_imp 23 2,064 12-31-2019, 12:26 AM
  2014 CB1100 Salvage title Honda_Fan_imp 38 2,417 01-29-2019, 02:28 PM
Last Post: rboe
  2014 CB1100 Std vs 2017 CB1100 ?? ohiorider_imp 14 1,268 12-22-2018, 10:49 AM
  2014 CB1100 alternator output ohiorider_imp 7 645 10-26-2018, 09:14 PM
  2014 CB1100 standard & sundry items SportsterDoc 22 1,467 09-11-2018, 10:42 AM
  cb1100 2014 New in Box jitaylor_imp 51 3,620 06-13-2018, 01:05 PM
Last Post: Chrisvillar98_imp
