front turn signals
Greg Davis_imp Offline
Threads: 15
front turn signals
Does anyone know how the front turn signals come off. I purchased some smaller turn signals, Lockhart Phillips, and am in the process of switching from stock to the L P smaller ones. No Problem on rear of bike, however, I can't figure out how the front signals come off. HELP!
01-30-2014, 03:21 AM
Ack-CB11_imp Offline
Threads: 46
RE: front turn signals
They have an allen bolt you need to get to on the inside that holds it to the bracket. 5mm IIRC
Post 4, picture 3
http://cb1100forum.com/forum/showthread....rn+signals
01-30-2014, 03:56 AM
Threads: 15
(01-30-2014, 03:56 AM)Ack-CB11_imp Wrote: They have an allen bolt you need to get to on the inside that holds it to the bracket. 5mm IIRC
Post 4, picture 3
Thank you, GOT IT. now I have to figure out how to mount the new ones. the link you sent was very helpful. thanks again. Greg
01-30-2014, 05:02 AM
ridesalot_imp Offline
Threads: 1
Greg, when I did this mod I used two stainless fender washers, one each between the light and the black Honda base. As I recall a hole has to be made in the center of the Honda base large enough to accept the bolt on the new light. Then, using a Dremel tool, I ground out the back of the Honda base in order to get the nut and a 17mm wrench in there to tighten the new light. You need to remove the headlight to do this.
When doing the wiring you will notice that there is only one hot wire to each light in spite of the fact that the lights also serve as running lights. You will only need a single element turn signal light to serve both purposes. The Honda computer does the rest. If you bought dual element lights, just ignore the running light wire.
01-30-2014, 10:45 AM
Threads: 15
(01-30-2014, 10:45 AM)ridesalot_imp Wrote: Greg, when I did this mod I used two stainless fender washers, one each between the light and the black Honda base. As I recall a hole has to be made in the center of the Honda base large enough to accept the bolt on the new light. Then, using a Dremel tool, I ground out the back of the Honda base in order to get the nut and a 17mm wrench in there to tighten the new light. You need to remove the headlight to do this.
Thanks so much. I finally got signals installed, all is good, love the small signals. Thanks for the help. Next is put low bars on.
02-03-2014, 01:44 AM
  LED Turn Signals deuce17EX 23 2,239 03-12-2024, 10:58 AM
  LED turn signals Elipten_imp 32 2,382 01-05-2023, 05:15 PM
Last Post: CptMoustache_imp
  Any aftermarket Turn signals plug and play? gretle_2.0 5 661 05-30-2022, 07:05 AM
Last Post: bioman_imp
  Turn signals option USA in EU Łukasz_imp 7 665 02-08-2022, 12:18 AM
  Identify these? Turn signals RandyBMC_imp 3 356 11-11-2021, 09:23 PM
  Anyone fitted Rizoma iRide turn signals to CB1100EX? Richard_imp 8 788 05-20-2020, 09:58 PM
Last Post: Richard_imp
  Lockhart Phillips Turn Signals-Lucas Tail Light ChipBeck_imp 43 3,022 04-17-2020, 07:25 AM
Last Post: gman_imp
  RELOCATION OF REAR TURN SIGNALS ART_imp 28 1,882 02-08-2019, 01:50 PM
  Self canceling turn signals Obleo 19 974 04-24-2017, 08:10 PM
Last Post: Tezza_imp
  Front turn signal mounting hole diameter c-breezy_imp 7 571 04-23-2017, 05:26 AM
Last Post: c-breezy_imp
