Front turn signal mounting hole diameter
c-breezy_imp Offline
Threads: 11
Hoping someone has the answer at hand, and apologies if it's already been covered (I searched) but does anyone know what size mounting bolts the front turn signal mounting holes will accept? I seem to recall that for at least one member, the holes were too small for the aftermarket signals that he purchased and thus, he had to drill.
Thanks in advance!
04-19-2017, 08:31 AM
PowerDubs_imp Offline
Threads: 125
Dunno, but I can measure stock blinker stems for you- brb.
04-19-2017, 08:34 AM
Threads: 11
That would be great - thanks PowerDubs!
04-19-2017, 08:36 AM
Threads: 125
The threaded hole for the bolt is about 6mm. There is a locating tab that keeps the blinker from rotating.
04-19-2017, 08:44 AM
Threads: 11
RE: Front turn signal mounting hole diameter
Wow - they are much smaller than I expected. I was considering some turn signals that used 10mm bolts - now I know what to look for!
Thanks again!!! Beer
04-19-2017, 09:30 AM
Lord Popgun Offline
El Supremo RLET Force
Virginia
Likes Given: 142
In the fiche, the front signal bolt size is 6x10 and the rears 6x14
04-19-2017, 09:46 AM
kennyw Offline
N9PHW
Sultan, WA
Threads: 42
Likes Received: 5 in 4 posts
Likes Given: 3
The holes on the rear are a lot larger than the bolts. I'm not sure about the fronts.
04-19-2017, 02:05 PM
Threads: 11
(04-19-2017, 09:46 AM)Lord Popgun_imp Wrote: In the fiche, the front signal bolt size is 6x10 and the rears 6x14
Thanks popgun! Can always count on you for a reference to the manual [Image: c846e3a0045d66f41609db49ab924263.png]
Has anyone mounted front turn signals that came with larger diameter mounting bolts in the stock location? I assume you'd just drill them out to be wider?
04-23-2017, 05:26 AM
  Turn Signal Indicators balkanhound_imp 5 700 04-17-2025, 11:17 PM
  2014 CB1100 Clear Turn Signal Lenses Ngavrielidis1_imp 16 1,534 04-15-2025, 06:23 AM
Last Post: Ngavrielidis1_imp
  Honda Top box mounting Lord Popgun 8 849 06-22-2023, 12:09 PM
  3D printed strap adapters for the CB1100 mounting pegs LayerCake_imp 33 2,274 07-10-2022, 12:04 AM
Last Post: 1973cb750
  Phone mounting issues ride4now_imp 37 2,705 09-29-2021, 05:42 AM
  Smaller turn signal/running light choices TxRonHarris_imp 33 2,647 07-06-2021, 10:00 PM
  Extra turn signal on dash Mixagon_imp 7 745 06-24-2021, 07:20 AM
Last Post: 17-CB-002
  Mounting a garage door remote Gone in 60 21 1,420 06-24-2021, 01:40 AM
  Turn Signal Relocation Cormanus 11 917 12-30-2020, 11:12 AM
  Signal Relocation Ben70_imp 7 765 02-20-2020, 10:22 AM
Last Post: Ben70_imp
