Removing badges from side panels
pechorin75_imp Offline
Threads: 11
So I'm thinking about removing the "CB1100" badges from my side panels. After a quick Photoshop job, I think I like it better that way.
Has anybody else done this? If so, any suggestions on how to best go about it?
I'm assuming that I can buy some kind of adhesive and put them back on if I change my mind...
03-07-2014, 06:18 AM
Likes Received: 618 in 276 posts
Likes Given: 789
RE: Removing badges from side panels
Post 17 ..Honda Lover can probably tell you whats involved. Hopefully he will come along shortly
[url=http://cb1100forum.com/forum/showthread.php?tid=2163&page=2]http://cb1100forum.com/forum/showthread....163&page=2
03-07-2014, 06:22 AM
Ack-CB11_imp Offline
Threads: 46
A little heat and they will peel right off. You can also use fishing line to slide under it and cut the adhesive. I wouldn't try to reuse them though, get these $30. Better looking
http://www.samurider.com/?p=18435
03-07-2014, 07:06 AM
Honda Lover_imp Offline
Threads: 4
(03-07-2014, 06:18 AM)pechorin75_imp Wrote: So I'm thinking about removing the "CB1100" badges from my side panels. After a quick Photoshop job, I think I like it better that way.
Ack-CB11 is spot on using a hair dryer. First, I advise taking a photo and quick placement measurements before you take the logo off so it will be easier to reapply should you decide later. From experience, a hair dryer will most definitely work. Take your time. First, aim the hair dryer on the logo for a minute or so to heat it up, making sure to move it back & forth across the whole logo. Then, place your finger at an end of the logo while aiming the hair dryer near the same end and gently lift the logo up. Keep moving the hair dryer in front of your finger along the logo as you slowly peel it up and away. Use a light microfiber and some mild detergent soap to remove any residue from the glue. In terms of re-applying, you can either use a light weight adhesive or new OEM logos are available from Babbitts House of Honda. (Recall less than $20 with shipping?). They are "peel n stick." I seem to remember someone on this forum who removed the logo on a cafe racer project and posted a photo. That would give you additional ideas how it will look if you want more in addition to photo shop. Speaking of photo shop, I would pay to have someone fill in the rear shock springs in yellow on my bike? I'm considering but not sure:
[url=http://s120.photobucket.com/user/sar11001/media/2014-03/671EC1C3-6F7D-4ADC-81FC-18C8B51A88EB_zpshtd4k2a2.jpg.html][Image: 7567795f872676031e364f3d8e7b6ac9.jpg]
03-07-2014, 08:11 AM
Threads: 11
Excellent...thanks for the help, guys. Sounds pretty straightforward.
You want Ohlins yellow on the springs? I should be able to mock that up for you pretty quickly.
03-07-2014, 08:30 AM
Scoobynut_imp Offline
Threads: 14
(03-07-2014, 07:06 AM)Ack-CB11_imp Wrote: A little heat and they will peel right off. You can also use fishing line to slide under it and cut the adhesive. I wouldn't try to reuse them though, get these $30. Better looking
I'm sure fishing line works well, but I use dental floss for this -- I've found Colgate brand floss is thinnest and slickest for getting under the adhesive.
03-07-2014, 08:32 AM
Threads: 11
Here you go. It's a little sloppy, but ought to give you the basic idea.
I actually got the idea after noticing that the badges were removed from the bike in the sample photos for the K&H seats. Thought it gave it a cleaner look.
03-07-2014, 08:50 AM
Threads: 4
You call it photoshop but I think your a magician. Thank you my friend! That's quite impressive! I greatly appreciate you taking the time.
03-07-2014, 11:58 AM
Likes Given: 789
I think they are magicians too. Cool skill to have.
I told my wife while watching a commercial the other night these computer guys could convince you that ANYTHING is real.
03-07-2014, 01:09 PM
Threads: 11
You're welcome, Honda Lover. It's fun to work on little projects like that.
03-08-2014, 12:04 AM
  valve stem replacement without removing tyre max 5 552 01-08-2021, 10:46 AM
  Removing stock rack on 2014 quiffy_imp 10 709 05-17-2020, 01:23 PM
   Side panel 1100/4 badges Frankie_imp 46 3,533 10-22-2019, 08:53 PM
  Advice for removing emblems on side covers misterprofessionality 26 2,011 05-01-2018, 07:28 AM
  removing black finish TCBronson_imp 12 800 09-26-2016, 12:30 PM
Last Post: Carguy1959_imp
  Removing stock mufflers? Rebel73_imp 24 1,524 02-19-2016, 03:52 PM
Last Post: Rebel73_imp
  Side Panels Interchangeable? 2013/2014 Mashup Stichill 6 531 04-20-2015, 07:18 AM
Last Post: Elipten_imp
  Removing reflectors from fork sliders Buffalorider_imp 11 696 03-07-2015, 09:22 PM
Last Post: twiin640_imp
  New seat and side panels available! CB4ME_imp 9 586 10-24-2013, 02:12 AM
Last Post: jamboa_imp
