Removing stock mufflers?
Rebel73_imp Offline
Threads: 79
Is there any write-up on this? My Over Racing mufflers came in today and I want to tackle it this weekend. I'm assuming it's relatively straightforward but I've never done it. The instructions that come with the slip-ons simply say to consult the service manual, which I don't have yet.
Sent from my LG-H901 using Tapatalk
02-10-2016, 01:45 PM
MikeOxbig_imp Offline
Threads: 8
RE: Removing stock mufflers?
I was going to respond but I have the Standard, not DLX. If it's anything like the Standard model, then it's super easy. Took me 15 minutes, just a few bolts here and there.
02-11-2016, 03:47 AM
Rebel73_imp Offline
Threads: 79
Cool, Mike. That's good to know. I can't imagine it would be much different for the DLX. Thanks.
02-11-2016, 03:53 AM
Threads: 8
You may want to use some thermal/exhaust paste to make sure no leaks. Some people say it's not necessary (and they are probably correct) but I did it anyway just to be safe. I actually used Teflon tape, supposedly an old trick that I discovered somewhere online (works wonders and you don't need to wait for it to dry/cure like the paste).
02-11-2016, 04:03 AM
JF Coastal_imp Offline
Threads: 23
Super easy. Few bolts and common sense. You got this. Post some pictures when done .
02-11-2016, 04:11 AM
Rebel73_imp Offline
Threads: 79
Cool, guys. Thanks for your input and tips. I'll post some pics and try to put up a video, too!
02-11-2016, 04:31 AM
Mike546_imp Offline
Threads: 4
(02-11-2016, 04:31 AM)Rebel73_imp Wrote: Cool, guys. Thanks for your input and tips. I'll post some pics and try to put up a video, too!
Are you selling your stock DLX mufflers?
02-11-2016, 06:29 AM
Likes Given: 1,010
You're the man, Rebel. I admire your confidence. As a klutz, one of the scariest phrases I know is "Super easy, just a few bolts ..." It always, always ends in tears.
02-11-2016, 06:53 AM
Rebel73_imp Offline
Threads: 79
(02-11-2016, 06:53 AM)Cormanus_imp Wrote: You're the man, Rebel. I admire your confidence. As a klutz, one of the scariest phrases I know is "Super easy, just a few bolts ..." It always, always ends in tears.
Ha ha. Well, my friend, in all honesty there have been several times where halfway through a project I told myself "Why didn't I just pay to have this done!!!???".
But somehow I've managed to fumble my way through through all of them and come out fine. It's all part of the learning process, I guess.
Also, the information available on forums like these helps alot.
Mike, I'm not sure. For the time being I will probably hang onto them because you never know. Should I decide to sell them I'll let you know.
(02-11-2016, 04:03 AM)MikeOxbig_imp Wrote: You may want to use some thermal/exhaust paste to make sure no leaks. Some people say it's not necessary (and they are probably correct) but I did it anyway just to be safe. I actually used Teflon tape, supposedly an old trick that I discovered somewhere online (works wonders and you don't need to wait for it to dry/cure like the paste).
Where did you get the tape? Home Depot?
02-11-2016, 07:03 AM
Threads: 8
I bought the Teflon tape from Amazon (since I was already ordering some other stuff from there anyway) but I'm very sure you can find it at Home Depot.
http://www.amazon.com/gp/product/B003D7K...ailpages00
Pretty self-explanatory but here's a good link with nice pics to show how it's applied to an exhaust:
http://www.s1000rrforum.com/forum/s1000r...ystem.html
02-11-2016, 08:34 AM
  Stock Mirrors MrBob_imp 5 558 04-11-2025, 03:33 AM
Last Post: balkanhound_imp
  Stock Exhaust Mod SStan11_imp 79 5,033 03-12-2025, 04:32 AM
  Stock Muffler jbird06_imp 8 744 05-02-2024, 11:21 AM
  delkevik slip on mufflers outback_imp 4 555 10-14-2021, 12:44 AM
Last Post: outback_imp
  Arrow slip on mufflers DougsZ28_imp 15 1,270 05-13-2021, 04:09 AM
  valve stem replacement without removing tyre max 5 541 01-08-2021, 10:46 AM
  Decat stock pipes ozigoo 4 471 05-22-2020, 10:55 AM
  Removing stock rack on 2014 quiffy_imp 10 708 05-17-2020, 01:23 PM
  Stock vs. aftermarket exhaust LongRanger_imp 15 1,040 11-30-2019, 06:30 AM
  Shaved Stock or K+H Low GroovyBunny86_imp 18 1,552 06-18-2019, 12:58 AM
Last Post: BayAreaRick_imp
