Front suspension?
#71
I Just cleaned out the stock dirty 10w fork oil and replaced it with 5W honda fork oil ...
Took a few rides in the local twisties and the rough local roads and 5W fork oil was the right way to go not the other 10/15/20 grades smooth and comfy on rough pavement and no more bouncing high rebound feel from the stock 10w fork oil.
Settled on 4 circles showing on front preload and second softest setting on rear for my 185-190 weight with gear and very nice soft and plush feeling without bottoming out at all even in heavy front braking
I'm still wondering why the stock springs are considered too soft for this weight range with preload within range .. For my skills and preference the 5w oil is a fantastic solution to smoothen the ride.
I once used auto tranny fluid (ATF) on a 1978 CB750 forks and that felt better so will try the ATF next fork oil change
  Suspension settings Whippa_imp 9 820 10-02-2020, 10:49 PM
  Suspension mods started ohiorider_imp 56 3,243 10-18-2017, 09:54 AM
Last Post: ohiorider_imp
  How common are wheel & suspension upgrades? Syscrush_imp 8 660 08-09-2017, 12:22 PM
Last Post: 736cc_imp
  Getting close to suspension mods ohiorider_imp 11 1,285 08-09-2017, 08:45 AM
Last Post: Syscrush_imp
  Wish me luck! (suspension upgrade) ohiorider_imp 5 507 07-14-2017, 02:49 AM
  Suspension the Ferret 22 1,346 05-04-2017, 07:34 AM
  Adjust rear suspension when going two-up? MikeOxbig_imp 5 501 11-01-2015, 02:18 PM
Last Post: kmoney_imp
  Suspension adjustment air charlie_imp 8 632 10-18-2015, 10:44 PM
Last Post: Brookland27_imp
  Higher Tire Pressure = More Suspension Compliance? Huladog_imp 24 1,455 09-07-2015, 12:58 PM
Last Post: 4 Paws_imp
  How is your suspension set? goldeneye_imp 7 539 08-17-2015, 03:38 AM
Last Post: Southpaw50_imp
