Adjust rear suspension when going two-up?
Anyone here adjusting the rear suspension when taking a passenger? Just curious, I'm 175 lbs and my suspension is at the softest setting. Planning to take my girlfriend on a ride (she's about 108) and was wondering if I should bother changing the suspension one notch firmer.
Well I weigh 150 and keep mine on one click harder all the time. Seemed to settle the rear end in corners better. I haven't had anyone else on the back but if I did and was riding any real distance, I'd adjust mine a little more.
(10-31-2015, 07:07 AM)Lord Popgun_imp Wrote: Well I weigh 150 and keep mine on one click harder all the time. Seemed to settle the rear end in corners better. I haven't had anyone else on the back but if I did and was riding any real distance, I'd adjust mine a little more.
I too would go one click harder if the roads around here weren't so crappy.
I always adjust the shocks prior to riding two up
absolutely tighten the preload on the rear at least. It's a 2 minute job and makes riding a passenger much easier and safer really
I've always done it as well. As I seem to recall that the US bikes didn't come with a shock wrench, so may have to get one at the dealer or Ebay.
  Suspension settings Whippa_imp 9 818 10-02-2020, 10:49 PM
  Balance shaft - is it time to adjust? And valve check question ohiorider_imp 9 599 06-23-2019, 06:04 AM
Last Post: ohiorider_imp
  Suspension mods started ohiorider_imp 56 3,240 10-18-2017, 09:54 AM
  How common are wheel & suspension upgrades? Syscrush_imp 8 657 08-09-2017, 12:22 PM
Last Post: 736cc_imp
  Getting close to suspension mods ohiorider_imp 11 1,285 08-09-2017, 08:45 AM
Last Post: Syscrush_imp
  Wish me luck! (suspension upgrade) ohiorider_imp 5 507 07-14-2017, 02:49 AM
  Suspension the Ferret 22 1,345 05-04-2017, 07:34 AM
  Front suspension? pechorin75_imp 70 6,027 03-20-2017, 01:34 PM
Last Post: IndianRider_imp
  Suspension adjustment air charlie_imp 8 631 10-18-2015, 10:44 PM
Last Post: Brookland27_imp
  Higher Tire Pressure = More Suspension Compliance? Huladog_imp 24 1,454 09-07-2015, 12:58 PM
Last Post: 4 Paws_imp
