Front suspension?
In looking through various threads on the forum, I don't see a lot of discussion about this...so I'm a bit reluctant to bring it up, because I don't want anybody to think I'm badmouthing the bike...
...but I've now adjusted the forks to the softest possible setting, and set the tire pressure a bit below the recommended value, and I still feel like my front suspension is excessively stiff. (I weigh 225, btw.) More than just firm--almost "bouncy." Enough that it takes effort to ride smoothly over even mild pavement irregularities, because it sends enough shock through the bars to cause unintentional throttle movements. In all the riding I've done (22 years, 8 bikes, ~ 150,000 miles), I've never experienced this before. For a while I thought maybe I was imagining things...but then I rode it back to back with my K1300S set to "sport" mode--which is pretty darn stiff--and the Honda was stiffer.
So what am I doing wrong? I've got four bars showing on the fork adjusters--which, unless I'm misreading the manual, is as soft as it gets. Should I be adjusting in the other direction for some reason? Is it possible there's some kind of issue with the forks? (Can they be set up improperly by the dealership?) Or am I just being a wimp?
Anyway, I'd appreciate any insights or suggestions you guys might have.
G'day pechorin. When I got my (second-hand) bike it was set up on the stiffest possible setting. I didn't notice for a bit—maybe until enzo pointed out to me—and have now adjusted it to the factory setting. I can't say I've noticed a similar problem on either setting. The suspension seems fine to me.
So I guess I can't help much.
G'day pechorin, I'm with Cormanus on this. My bike came factory set. Since then I have increased the rear spring preload by one notch to compensate for a little "wallow" during cornering, loaded with baggage. The front is soft but not overly so, compared to the VFR 750 at least. I may firm it up a little to trial it.
Have you taken it to a dealer or shop? That would be my suggestion.
Bad mouthing? No such thing. I think it's called constructive criticism Smile
is your machine new, did you take delivery from a dealer? if so I would suggest a visit to a dealer for a quick check for front fork binding. this can be caused by improper assembly of the fork assembly's to the upper and lower bridges(uneven height) or improper assembly procedure of the front axel/wheel assembly into the lower fork cases,(lower fork cases forced together or spread apart) causing the fork cases to bind when sliding up and down the fork tubes.
more questions? want self help? just ask, we riders here are eager to help if we can.
Paul.
If the forks have been opened, the wrong fluid height would cause this also.
you didn't mention the rear suspension. If it is soft & bouncy your bike is not balanced. go up anouther notch or two on rear.
I found the suspension to be on the soft side. For a quick check put two zip ties on fork, put your setting back down to two lines showing (which I believe in normal) on level ground hold the front brake and compress the shock with your weight over the front end and see what the travel is measuring from the zip to the top of the shock. Maybe someone of similar weight can do the same to compare ( my bike is apart right now) At least you will be able to tell if there is binding in the triples or a fluid issue. I would try this before you bring it in to the dealer.
"see what the travel is measuring from the zip to the top of the shock".
I think he means to the top of the lower fork leg (where the fork seal is).
Thanks for the responses, guys. I bought the bike earlier this year with around 900 miles....I have no evidence that the forks have ever been apart--but also no evidence that they haven't. One other detail I didn't mention: When I bought the bike, there was only one line showing on the adjusters. Taking it to three lines, and then finally "wide open," I've noticed very little (if any) change in the way the front end feels.
Vfrpaul, interesting possibilities. Would what you're describing cause other issues as well--like sticking in one position, or one fork compressing and the other not?
(04-27-2014, 11:35 PM)The ferret_imp Wrote: "see what the travel is measuring from the zip to the top of the shock".
Thank you Smile
  Suspension settings Whippa_imp 9 847 10-02-2020, 10:49 PM
  Suspension mods started ohiorider_imp 56 3,296 10-18-2017, 09:54 AM
Last Post: ohiorider_imp
  How common are wheel & suspension upgrades? Syscrush_imp 8 679 08-09-2017, 12:22 PM
Last Post: 736cc_imp
  Getting close to suspension mods ohiorider_imp 11 1,296 08-09-2017, 08:45 AM
Last Post: Syscrush_imp
  Wish me luck! (suspension upgrade) ohiorider_imp 5 511 07-14-2017, 02:49 AM
  Suspension the Ferret 22 1,353 05-04-2017, 07:34 AM
  Adjust rear suspension when going two-up? MikeOxbig_imp 5 503 11-01-2015, 02:18 PM
Last Post: kmoney_imp
  Suspension adjustment air charlie_imp 8 634 10-18-2015, 10:44 PM
Last Post: Brookland27_imp
  Higher Tire Pressure = More Suspension Compliance? Huladog_imp 24 1,469 09-07-2015, 12:58 PM
Last Post: 4 Paws_imp
  How is your suspension set? goldeneye_imp 7 539 08-17-2015, 03:38 AM
Last Post: Southpaw50_imp
