How is your suspension set?
Hey guys, I have a brand new CB1100, and I was wondering how you have your suspension set. If it helps, I weigh about 235 lb and 6'0''. I have some soft luggage on the rear seat that may be loaded with 30-40 lb on long trips and likely just the essentials (including a small tool kit and such) on normal ride.
Thanks in advance.
Second from highest click on the rear and two bars showing on the front forks. We weigh the same, but I don't have it set for luggage. This setup is probably a bit hard, but I like how the handling is with the preload cranked up.
The best way to do it is just take the tool with you (you can even do the front with a coin on the go) and go on one of your favorite rides to dial it in.
Is the adjustment tool in the small tool kit that comes with the bike? If not, where can I find one?
No, you do not get a rear shock adjusting tool in the woefully small tool kit. See your local dealer for one. If they are well equipped they may have one they can sell you. Otherwise they will have to order it.
(08-16-2015, 12:04 PM)kmoney_imp Wrote: Second from highest click on the rear and two bars showing on the front forks. We weigh the same, but I don't have it set for luggage. This setup is probably a bit hard, but I like how the handling is with the preload cranked up.
I'll go with that.
(08-16-2015, 01:53 PM)Redbird_imp Wrote: No, you do not get a rear shock adjusting tool in the woefully small tool kit. See your local dealer for one. If they are well equipped they may have one they can sell you. Otherwise they will have to order it.
You blokes got short changed. The Oz '10 models came with a full toolkit, including a shock adjusting tool. Maybe that's why ours cost so much.
Dito here on those settings, although I weigh a bit less. Also UK bikes come with the adjusting tool.
I just did a two week tour, two up with full luggage. Went up to highest preload on the rear and one line showing on the front. Helped stop the front end diving when riding thru towns. Handled really well...
Canada gets the full tool kit too. We got squat in the US!
I maintain the stock setting for my suspension. As for tools, I kept the kit from my 2003 Nighthawk when I traded it in.
  Suspension settings Whippa_imp 9 890 10-02-2020, 10:49 PM
  Suspension mods started ohiorider_imp 56 3,751 10-18-2017, 09:54 AM
Last Post: ohiorider_imp
  How common are wheel & suspension upgrades? Syscrush_imp 8 726 08-09-2017, 12:22 PM
Last Post: 736cc_imp
  Getting close to suspension mods ohiorider_imp 11 1,341 08-09-2017, 08:45 AM
Last Post: Syscrush_imp
  Wish me luck! (suspension upgrade) ohiorider_imp 5 549 07-14-2017, 02:49 AM
  Suspension the Ferret 22 1,528 05-04-2017, 07:34 AM
  Front suspension? pechorin75_imp 70 6,542 03-20-2017, 01:34 PM
Last Post: IndianRider_imp
  Adjust rear suspension when going two-up? MikeOxbig_imp 5 526 11-01-2015, 02:18 PM
Last Post: kmoney_imp
  Suspension adjustment air charlie_imp 8 666 10-18-2015, 10:44 PM
Last Post: Brookland27_imp
  Higher Tire Pressure = More Suspension Compliance? Huladog_imp 24 1,606 09-07-2015, 12:58 PM
Last Post: 4 Paws_imp
