Suspension mods started
Installed IKON shocks (7610-1507-SP17) with lighter (Code 215) springs. To date, I've ridden approx. 150 miles with the new shocks. Rear end feels much more compliant. Preload and rebound damping on lightest settings at this time, but think I'll need to dial in a bit more damping. Still to do ..... the Traxxion Dynamics fork kit. A bit more work than simply changing the rear shocks, but I'll get it done.
Please post updates, quite interested in your observations. Why those shocks and that weight?
I'd be interested in the choice of fork upgrade. Do you ride aggressively and want a firmer front end?
(08-29-2017, 11:02 AM)4 Paws_imp Wrote: Please post updates, quite interested in your observations. Why those shocks and that weight?
My choice to select the lighter springs was to first give them a try. I don't often ride double, and I weigh 160 pounds. The stock rear shocks felt like my weight didn't even begin to compress the springs. Ikon indicated they would replace the light springs with a heavier set for a very modest price, if I found the light springs too light, so that's the reason for initially going with the lighter springs.
Re why these shocks, the price wasn't too bad, they had four rebound damping rates, they are rebuildable, and they could be ordered to cosmetically look much like the OEM shocks. Plus, dealing with Ikon USA on the phone was a good experience.
Bob
Here's a quick update. Today was the first ride when I thought I'd reset the rebound damping rate from light to heavier, after experiencing a higher kickback than expected. So I set them at 1.5 instead of 2, 3, or 4. Since I noticed the rebound was somewhat harsh, I contacted Ikon USA and asked if the shocks had several positions between 1 and 4. Answer was 'no,' the rod I turned when changing from lighter to heavier rebound damping contains 4 orifices of varying size. Setting the rebound at, for example, 1.5, does not align an orifice where it needs to be. It needs to be rotated to 1, 2, 3, or 4. Makes sense.
(08-29-2017, 12:21 PM)PowerDubs_imp Wrote: I'd be interested in the choice of fork upgrade. Do you ride aggressively and want a firmer front end?
No, I am not an aggressive rider. I've ridden for years on older Beemers with extremely soft suspension. What I'm shooting for is suspension that lets me ride my CB solo over less than perfect road surfaces, but with a feel more like a cartridge fork vs damper tube. I asked Traxxion Dynamics to supply a fork kit that would (a) accommodate my weight, (b) type of riding, and © my suspension goal, ie compliant over less-than-perfect road surfaces. The Traxxion Dynamics kit comes with RaceTech Gold valves that should be an improvement over the stock damper rods. Not looking for firmer, but for more compliant suspension over a variety of road surfaces. Guess I've ridden and adapted to Beemer soft suspension over the years. I think the Germans called the older airhead a 'gummikuh' or rubber cow.
[/quote]What I'm shooting for is suspension that lets me ride my CB solo over less than perfect road surfaces, but with a feel more like a cartridge fork vs damper tube. Not looking for firmer, but for more compliant
[/quote]
I hope they are able to provide that- but based on what I have read, that kit tends to be more firm and sporty- which is a big part of my reason to buy the '17 Showa SDBV forks instead.
What I'm shooting for is suspension that lets me ride my CB solo over less than perfect road surfaces, but with a feel more like a cartridge fork vs damper tube. Not looking for firmer, but for more compliant.
[/quote] I hope they are able to provide that- but based on what I have read, that kit tends to be more firm and sporty- which is a big part of my reason to buy the '17 Showa SDBV forks instead.
Lets hope they gave me the straight scoop. I think they did. I can definitely say that the Ikons have improved the rear suspension of the bike (for my purposes.) When I talked with Traxxion Dynamics, they wanted to know my goal (more compliant suspension over a variety of road surfaces.) Wanted my weight. Wanted to know if I used the bike solo or with passenger (answer = solo.) No part of my discussion with them indicated I wanted more sporty suspension. I think they understood what I wanted. I'll know once the kit is installed. As you know, Traxxion Dynamics can supply a variety of fork springs, and the RaceTech valves can be tuned for a variety of uses.
[/quote]
i dont know...a enduro like the GS from BMW has extra long suspension-way....bcos this its too comfortable on bad streets.....and /but specaly soft on normal streets.....
Adjustable pull and pressure stage/ rebound damping rate from the suspension is a other story...every kind street needs a own adjustment if you want it still optimal , ask a racing driver....
and simple progressive suspensions are not that much flexible with adjustment
(08-29-2017, 06:03 PM)alprider_imp Wrote: and simple progressive suspensions are not that much flexible with adjustment
Actually, the springs with the Traxxion Dynamics kit aren't progressive, but as I understand it, a straight rate spring, ie, not wrapped to act as a progressive spring. If you question my assessment of the Traxxion kit, maybe someone from their company can chime in and describe the kit, vs me paraphrasing what I think I heard. I'll ask the next time I talk with them.
(08-29-2017, 04:57 PM)alprider_imp Wrote: i dont know...a enduro like the GS from BMW has extra long suspension-way....bcos this its too comfortable on bad streets.....and /but specaly soft on normal streets.....
can you give us an example of :
Adjustable pull and pressure stage/ rebound damping rate from the suspension...
it's hard to understand what you posted above...
  CB1100 parts discontinuation has started bflint 24 2,380 11-12-2020, 12:24 AM
Last Post: Bazbro_imp
  Suspension settings Whippa_imp 9 818 10-02-2020, 10:49 PM
   CB1100 mods Timpo_imp 175 12,426 04-10-2020, 01:48 AM
Last Post: quiffy_imp
  Great Day to Ride? Seat Mods Whippa_imp 14 2,350 01-28-2020, 06:02 AM
Last Post: Whippa_imp
  I need slight ergonomic mods ohiorider_imp 1 237 04-22-2019, 09:08 PM
  How common are wheel & suspension upgrades? Syscrush_imp 8 657 08-09-2017, 12:22 PM
Last Post: 736cc_imp
  Getting close to suspension mods ohiorider_imp 11 1,285 08-09-2017, 08:45 AM
Last Post: Syscrush_imp
  Wish me luck! (suspension upgrade) ohiorider_imp 5 507 07-14-2017, 02:49 AM
  Suspension the Ferret 22 1,345 05-04-2017, 07:34 AM
  Front suspension? pechorin75_imp 70 6,027 03-20-2017, 01:34 PM
Last Post: IndianRider_imp
