O2 sensor eliminator — why?
#61
(07-13-2015, 06:19 AM)veech_imp Wrote: Thanks Gumby. That is what I thought, just figured I should check with the experts. BTW, that is why I have had my O2 eliminator & plug sitting in a box for the last year. The bike runs great as it is and I haven't wanted to mess with the headers either until I had an additional reason to do so.
If you have an eliminator, it just plugs into the wiring harness, and your done. No need to drop headers and remove the actual sensor itself.
I believe that veech understands that.
What he and others like myself are concerned about is that the O2 Sensor will foul beyond repair if not removed. With it unplugged but left in the header, the preheat circuit will not burn off any carbon and the sensor will just continue to coke up. Then, if one decides to remove the Eliminator Plug at a later date, the O2 sensor would likely be toast and need to be replaced. At $200 or more, that is not a cheap proposition.
Yes, that is it exactly Gumby! Thank you Sir. Cool
I remember seeing similar discussions on the Triumph site. My wife had an EFI Bonnie and it did seem to smooth out a bit when the O2 was removed. The 2014 DLX I recently got has no such issues...I'm figuring if it ain't broke I ain't gonna fix it. - Karl
After doing some reading and purchasing one of these O2 eliminators, I installed it in my bike last night. All traces of the initial sputter when accelerating from a stop or driving at steady low RPM's are completely gone. Throttle response is smooth as butter now. Such a cheap mod to give such a drastic performance improvement.
Get one! Wink
(07-19-2015, 01:00 PM)kvdv_imp Wrote: I remember seeing similar discussions on the Triumph site. My wife had an EFI Bonnie and it did seem to smooth out a bit when the O2 was removed. The 2014 DLX I recently got has no such issues...I'm figuring if it ain't broke I ain't gonna fix it. - Karl
I dont notice anything with mine either Karl. I wish I had ridden some of the other CB's at the rally for guys that say their bikes had this issue because I have never felt anything but creamy smoothness. Also wish I had ridden and tested someone elses bike that says their rear brakes were strong, because I've had 2 and the rear brakes have been poor ( IMO) on both of them.
I never really had any serious issues with engine management, the CB being so much better than most EFI bikes, but had noticed a little sputter at low steady throttle at times. Bypassing the O2 sensor eliminated that small annoyance and made my CB smooth as a perfectly setup carb equipped bike.
For the most part I have ignored this thread, but decided to read through it since I had some time on my hands.
Interesting reading and interesting conclusions.
I'm with the ferret and another poster, my bike is creamy/silky smooth from start, idle and all the way through the rev range.
Strange how some are having a problem and some aren't. (?)
Anyway, it ain't broke so I too am not going to fix it.
I don't think the oxygen sensor heater is meant to "clean" the sensor. The HO2S won't generate a signal until it reaches around 600 degrees F. Almost all sensor heaters only work a short amount of time because once the engine reaches normal operating temperature, the heat of the exhaust is sufficient to maintain 600 F. I'm pretty sure the proper fix for a "sputtering" problem isn't defeating the closed-loop/feedback system, but unless/until my bike sputters, I'll likely never know. Wish me luck.
(09-05-2015, 09:15 AM)immgunn_imp Wrote: I don't think the oxygen sensor heater is meant to "clean" the sensor. The HO2S won't generate a signal until it reaches around 600 degrees F. Almost all sensor heaters only work a short amount of time because once the engine reaches normal operating temperature, the heat of the exhaust is sufficient to maintain 600 F. I'm pretty sure the proper fix for a "sputtering" problem isn't defeating the closed-loop/feedback system, but unless/until my bike sputters, I'll likely never know. Wish me luck.
You are probably correct. I based some of my earlier comments on an actual suggestion that I received from the manufacturer/supplier of the O2 Sensor Eliminator Plugs. He provides the O2 Lambda Sensor block-off screw in most of his kits because he stated that it is safer to remove the sensor if you ever intend to run a closed loop system again at a later time. Whether the preheat circuit helps to "clean" or not was really my interpretation, but he was concerned about the long term damage to the sensor if it is left in place and unused.
The true test will be to see if a sensor that was left in the header still works after using an eliminator plug for a year or more.
  O2 sensor eliminator not working on CB1100rs 2017 tory_imp 33 2,571 03-06-2026, 04:31 AM
  Oxygen lambda o2 sensor eliminator kit Davidjill_imp 4 550 11-09-2025, 06:23 AM
Last Post: AndyBeeMD
  Public Service Announcement - Speed Sensor Clip Gone in 60 7 826 10-22-2025, 02:11 PM
  How to remove O2 sensor CB1100AZ_imp 10 844 12-13-2024, 09:57 AM
Last Post: inditx_imp
  Bank angle sensor. Tezza_imp 8 733 08-06-2023, 05:57 PM
Last Post: Jurlie_imp
  fuel level sensor MBZM Rai_imp 11 876 04-11-2023, 11:38 PM
  How to remove 2013 Rear ABS/Speed sensor danieljrmurray_imp 16 1,296 06-03-2022, 01:16 PM
  HONDA Oxygen Sensor Eliminator CB 1100 2013-2016 Enzofour_imp 1 266 03-07-2021, 05:16 PM
Last Post: jtopiso_imp
  speed sensor output Lord Popgun 16 1,072 10-09-2020, 09:20 AM
  oxigen sensor tutorial max 18 962 05-08-2019, 10:59 AM
