Spark Plugs
#61
Solid tip [url=http://cb1100forum.com/forum/member.php?action=profile&uid=3454]PB. Thumbs Up
Yup, thanks, all done, I removed the tank for sake of it, as it turns out I even had a special tool [Image: 8cf6fe798eb7be7eb00c341ea64a99eb.png]
Anyhow, thank you for the tip, I actually only disconnected the quick connector and turned the tank around counterclockwise on the seat.
Air element was a hassle, stuff that is under my right side cover looks nothing like the workshop manual picture. Off to put in fork gaters. That's for a different thread tho[Image: 7c163879a744afa8b7793b4bfa247f80.jpg][Image: 2f3e37a2cf8d96edd4341f31d1b0110b.jpg][Image: b2c445d66562217bc97184f7c456ebc9.jpg][Image: bd33dd11d2938e441a772541a6cee685.jpg][Image: 191fb6ff4cb31ded45c35766aab8cdf2.jpg]
'14 CB1100 STD 5 speed
I think the plugs are costly because of the low production quantities involved. Is the CB1100 the only bike these work in? Could be. The long threads to accommodate the oil passages give them a unique form factor, for sure.
I bought the rest of the OEM tool kit from Honda and the spark plug wrench is a good one with a 10mm hex extension on top that will take a box end or socket wrench.
(12-17-2020, 01:42 AM)LakeWylieJoe_imp Wrote: I think the plugs are costly because of the low production quantities involved. Is the CB1100 the only bike these work in? Could be. The long threads to accommodate the oil passages give them a unique form factor, for sure.
Well considering that I found them for 6$ a pop, they are not that expensive. But yes, they are only made for this bike and no other
Great show pics Tod. Forum gets a clearer idea of what's under the skirt.
(12-17-2020, 09:13 AM)GoldOxide_imp Wrote: Great show pics Tod. Forum gets a clearer idea of what's under the skirt.
"Under the pants" sir, my CB is a steed. All my bikes were/are male, it's a bro-love, never romantic lol
My friend ; how many time/kilómeters was from the last change ????
(12-17-2020, 02:06 PM)Alfgaxatico_imp Wrote: My friend ; how many time/kilómeters was from the last change ????
I don't think the plugs were ever changed. They are not bad, just rusty as the bike has been sitting for a while, outdoors I suspect. Current ODO is around 13000km
If you change your spark plugs make certain that you use high pressure air to blow away any dirt around the plug. After loosing them a few turns use air pressure again as sometimes a little dirt/sand/grit was lodged under neat the plug.
Yes I blew in and around the holes, hope that's enough pressure because it's all it's going to get, I don't have and don't plan on getting a compressor any time soon. Work with what you've got is tbe name of the game [Image: f0ccd1e13cb3aff03ba1f8444b42ffad.png]
  NGK spark plug options Jonnyteabag_imp 6 644 08-05-2026, 11:35 PM
Last Post: JRD
  spark plugs after 70.000 Km DAC 16 1,599 12-23-2025, 10:15 AM
  'Factory' high performance spark plugs PowerDubs_imp 17 1,505 10-23-2024, 02:50 PM
Last Post: rtmoto1
  Spark plug socket. Jgarciajr40_imp 5 572 09-11-2023, 10:40 PM
Last Post: Jgarciajr40_imp
  spark plugs NGK LMAR8A-9S louied_imp 1 337 06-27-2023, 01:19 PM
  2017 CB1100EX Accessory Plugs TXBikerGuy 13 1,202 06-24-2023, 08:27 AM
  spark plug caps alexzanutto_imp 3 417 01-29-2023, 06:21 AM
Last Post: artashline_imp
  spark plug help, please !! The Gecko_imp 10 792 10-08-2022, 12:22 PM
  CB 900C Custom Spark Issue goatman64_imp 3 377 11-27-2021, 07:11 AM
  Strength to tighten the spark plugs. syncronizator_imp 27 3,057 01-07-2020, 06:53 AM
