Brake reservoir screw head issue
#61
How do I test for loose screws ? sit on a sofa, neck muscles as loose as possible, look up ... and bang your head from the left or right with your palm ?
(04-24-2022, 07:52 AM)j3gq_imp Wrote: How do I test for loose screws ? sit on a sofa, neck muscles as loose as possible, look up ... and bang your head from the left or right with your palm ?
Yeah....a 2x4 wooden plank would deliver better and permanent results than palm Smile
You CAN NOT test for a loose screw yourself , someone else will tell you if you have one.....
...loose Smile
It's out.Excited
The smaller (3 mm) extractor got stuck in the screw and I was beginning to wonder if I'm going to make it worseConfused. Rotated the 3mm extractor out and moved on to the 4mm extractor. It came out easily. In hindsight, I think the chuck on the drill wasn't tightened enough for the 3mm extractor.
The screw which came out looked ok - but had some of the white powdery stuff in the center.
The new screw did go in easy - so it looks like the threads are good on the reservoir.
Pads replaced. Rode for a short distance and things seem to be good. Now to move on to the speedbleeder installs and bleed the fluids all around - what could go wrongDodgy?
Thanks for all the suggestions and encouragement.
Hoooray! Congrats
Awesome satchit, congratulations.
A story with a good ending.
Congratulations, Satchit, and well done for persevering. Thumbs Up
Well done, mate.
Nice job Sach, and good pictures too by the way so we all learned something today.
But why one thread is corroded and not the other?
Could be some brake fluid made it's way into the thread previously, easily done when removing the cover and mixed with moisture ( hygroscopic means it attracts moisture ) and started corroding the aluminum housing similar to salt and moisture.
Some grease or gear oil ( spreads out on a surface and wicks in a crevice ) would have reduced this and regular fluid changes would have limited the time corrosion had settled in, even" excersising" the screws a bit would have helped.
Something you have more control over instead of " done by the dealership ".
  JIS screw drivers Ridem32_imp 26 1,550 06-12-2026, 06:56 PM
  Help from the hive mind: Intermittent Starter Issue (2017) JRD 10 492 01-30-2026, 02:16 PM
Last Post: JRD
  Shifting issue Cormanus 31 2,099 05-15-2024, 12:59 AM
  Sight Glass Screw Mickey Dublin_imp 16 1,435 11-22-2023, 08:25 AM
  Arrow Slip on issue - stock gasket didn’t fit Ddawg1144_imp 4 438 02-21-2023, 07:51 AM
  Fuel reserve display issue Banksy_imp 2 271 06-29-2022, 04:37 AM
  Chrome cylinder head cap Juancho76_imp 21 1,516 04-03-2022, 08:48 AM
Last Post: Juancho76_imp
  Mechanical issue and hello again RickNRoll53_imp 8 636 12-16-2021, 06:46 AM
  CB 900C Custom Spark Issue goatman64_imp 3 345 11-27-2021, 07:11 AM
  Cams, Compression, Head Work? boynton6spd_imp 12 843 08-08-2021, 02:27 AM
Last Post: old blue_imp
