Sight Glass Screw
I tried searching and found no mention of this.
Does everyone else's oil sight glass have a small screw in the middle. If I could upload a picture, I would. But just picture a small flat head fastener of some kind, with small rubber washers on the inner and outer sections. Is this normal?
If not, why would somebody have put a screw in the sight glass. Thanks everyone
yes it's a windshield wiper use a small screwdriver to wipe it back and forth
(11-18-2023, 06:23 AM)The ferret_imp Wrote: yes it's a windshield wiper use a small screwdriver to wipe it back and forth
I heard that on the 2024 models, that screw will be turned by a servo motor, controlled by AI. Angel
I haven’t ever even turned mine.
But since technically this is an oil thread— I don’t turn it as I’m afraid the wiper will rub the engine wear particles against the glass. That would thin the glass and then maybe cause it to fail and let all the oil out. Hey! It could happen… Big Grin
ROFL
ROFL
bacon
(11-18-2023, 06:53 AM)Lord Popgun_imp Wrote: I haven’t ever even turned mine.
OMG!!
[Image: 88e9338d63fa5c26af34f7a96ddbd922.gif][Image: 3759ba5483a579ae8db69ffad5015b24.gif]
You know, when you think about the old days of the Honda CB1100, I don't think anyone on the Forum (??) has ever expressed a leak from the wiper-screw-based engine oil sight glass. I would have to say Honda did an okay job in that regard. Way back before I acquired the 2014 model, I looked at that and thought, " ... yikes, how long is this gadget going to last?".
(11-18-2023, 09:50 AM)GoldOxide_imp Wrote: You know, when you think about the old days of the Honda CB1100, I don't think anyone on the Forum (??) has ever expressed a leak from the wiper-screw-based engine oil sight glass. I would have to say Honda did an okay job in that regard. Way back before I acquired the 2014 model, I looked at that and thought, " ... yikes, how long is this gadget going to last?".
I think they first appeared on the 1975 Gold Wing, and used on the bigger bikes. Never seen any that leaked.
Thank You! I'm sorry if this is making an a** of myself as a new member. I have just never seen such a thing!
Big Grin I must apologize for starting another dreaded oil thread. Thank you all for the explanation, though.
I'm not sure if I used the search correctly. I assume this has been discussed before, but I got no results.
  JIS screw drivers Ridem32_imp 26 1,645 06-12-2026, 06:56 PM
  Brake reservoir screw head issue satchit 72 5,299 04-24-2022, 11:55 PM
  glass j3gq_imp 15 1,238 03-08-2022, 10:11 AM
  Dealing with a stuck JIS screw Stichill 28 2,206 06-27-2021, 10:21 AM
Last Post: Stichill
  JIS Cross Head Screw Drivers 2017EX_imp 15 1,283 04-15-2020, 01:53 AM
  Speedometer Allen Head screw loose mhicks17_imp 1 245 09-15-2018, 02:55 PM
Last Post: max
  JIS Screw Drivers & Screw Driver Bits 2017EX_imp 8 755 06-04-2018, 12:22 PM
Last Post: Stichill
   Beam adjustment screw :) Riko_imp 13 1,059 06-11-2017, 10:50 PM
Last Post: White Dog_imp
  Oil Level Sight Glass Question olekzap_imp 9 735 07-01-2016, 06:59 AM
Last Post: Ulvetanna_imp
  screw in front tire Krupator_imp 25 1,531 06-20-2016, 11:10 AM
Last Post: pw363_imp
