Clutch/Brake fluid
#51
(02-22-2019, 04:54 AM)peterbaron_imp Wrote:
(02-22-2019, 03:16 AM)peterbaron_imp Wrote: Quick clutch test:
1. standing at the bottom of an incline ( min 40 ft)
2. be in the 2nd or 3rd gear and try to take off...if clutch is healthy, you should be able to make to the top ( bike will make a bit of an effort)
3. if you didn't , you already know, clutch slipping
4. this is NO or YES test if your problem is tricky or intermittent
CORRECTION TO #4
This is NOT a NO or YES test if your problem is tricky or intermittent
CORRECTION TO #4
Gotcha.
  CLUTCH FLUID CHANGE SUPERCRUZ_imp 15 1,335 12-24-2025, 11:14 AM
  Replace clutch Lever Davidjill_imp 10 1,013 02-06-2025, 01:27 AM
  Clutch Plates finally going? misterprofessionality 12 1,090 11-22-2024, 07:49 AM
  Brake fluid flush CB1100@2013: photos valkyrie_rider_imp 0 259 02-13-2024, 10:28 AM
Last Post: valkyrie_rider_imp
  Clutch fluid change CB1100@2013: photos valkyrie_rider_imp 0 253 02-13-2024, 10:27 AM
  Clutch Fluid Wagonpeddler_imp 32 2,672 06-14-2023, 08:09 AM
Last Post: bvictory_imp
  Clutch Not Working Henrik_imp 7 660 04-24-2023, 06:43 PM
Last Post: Henrik_imp
  Clutch pull mpuhl_imp 4 520 02-21-2023, 10:48 AM
  Synthetic Brake Fluid Wagonpeddler_imp 3 389 02-18-2023, 07:49 AM
  Clutch slave cylinder gasket Maturecheese_imp 3 400 01-27-2023, 12:33 AM
Last Post: Maturecheese_imp
