Brake reservoir screw head issue
#51
Satchit, any progress to report after 10 days?
A lot of post for ONE little screw !
(04-20-2022, 07:53 PM)lash_imp Wrote: Not sure what your mechanic was thinking about, but if you drill the head out you will not touch the threads. it will just take the top of the screw off and leave the shank in place which you remove after you take the reservoir top off.
The mechanic was concerned about drilling too deep.
My concern is drilling too wide - I've gouged out a fair bit of the head. So, I'm going to need a small dead center pilot hole.
I've ordered one of [url=https://www.thegrabitstore.com/collections/featured-products/products/alden-4507p-grabit-micro-broken-bolt-extractor-4-piece-kit]these - which should handle the M4 screw. Will be delivered early next week. I'll probably start with the smallest one and if that doesn't work move on to the one for the M4 screw.
If the above doesn't work, then I'll move on to the destructive approaches. pekingduck's suggestion for just cutting the cover is a good idea.Thanks
Thumbs Up
Slow and gentle. Good luck.
Hope everything works out okay for you, Satchit. I bought the Vessel JIS impact screwdriver on Amazon and really like it. Of course you do not have to hit it with a sledge hammer, it also works very well with gentle pressure. I used it like a regular screw-driver and it worked beautifully. Glad to have this excellent tool in my collection.
I have several of these if anyone really needs one that badly. Be glad to send you a couple. I bought extras some time back after stripping one on the old GS750 I sold last year.
(04-22-2022, 02:57 AM)Houtman_imp Wrote: A lot of post for ONE little screw !
I suppose we just like talking about rust of corrosive subjects of all sorts.
Yes, perhaps it is better to have a screw too tight than having a screw loose ....
(04-23-2022, 10:06 AM)Houtman_imp Wrote: Yes, perhaps it is better to have a screw too tight than having a screw loose ....
ROFL
^^+1 ROFL^^
  JIS screw drivers Ridem32_imp 26 1,550 06-12-2026, 06:56 PM
  Help from the hive mind: Intermittent Starter Issue (2017) JRD 10 492 01-30-2026, 02:16 PM
Last Post: JRD
  Shifting issue Cormanus 31 2,099 05-15-2024, 12:59 AM
  Sight Glass Screw Mickey Dublin_imp 16 1,435 11-22-2023, 08:25 AM
  Arrow Slip on issue - stock gasket didn’t fit Ddawg1144_imp 4 438 02-21-2023, 07:51 AM
  Fuel reserve display issue Banksy_imp 2 271 06-29-2022, 04:37 AM
  Chrome cylinder head cap Juancho76_imp 21 1,516 04-03-2022, 08:48 AM
Last Post: Juancho76_imp
  Mechanical issue and hello again RickNRoll53_imp 8 636 12-16-2021, 06:46 AM
  CB 900C Custom Spark Issue goatman64_imp 3 345 11-27-2021, 07:11 AM
  Cams, Compression, Head Work? boynton6spd_imp 12 843 08-08-2021, 02:27 AM
Last Post: old blue_imp
