Engine mount bolt torque value
#41
I just installed SW-Motech's on my bike. One of the bolts had some oxidation but not as bad as pictured. I made sure to use loctite on the nuts securing the frame Bolts in place.
Also, others have recommended wrapping up the lower portion of the frame prior to mounting the U-bolt clamp to prevent scuffing of the frame itself
They seem to blend fairly well for the post part
[Image: 19e94bd96883ab24ea3a0190470f5f2d.jpg]
@E11even_Hunnit, I see you didn't install engine guards in time Smile
(07-31-2020, 09:19 AM)mrded_imp Wrote: @E11even_Hunnit, I see you didn't install engine guards in time Smile
Unfortunately that was done by the previous owner. I got the bike that way Shy
I like your bike mate
  Pictures of OEM Rear turn signal mount Houndwheels_imp 8 761 09-12-2023, 10:28 AM
Last Post: Houndwheels_imp
  Front sprocket bolt cant be moved misterprofessionality 55 4,453 03-13-2023, 12:18 PM
  Torque value question Jonnyteabag_imp 9 656 03-10-2023, 01:00 AM
Last Post: 1973cb750
  2014 cb1100 Torque specs for two specific locations Dd808_imp 8 644 09-08-2021, 11:07 AM
Last Post: Dd808_imp
  Handlebar bolts torque value? (CB1100RS -18) Olof_imp 3 402 04-03-2021, 01:35 AM
  Fork Tube hex head bolt tool fitment ? bflint 8 695 11-30-2020, 06:24 PM
Last Post: jtopiso_imp
  Location of Engine Number on Engine? cb1100_dude_imp 2 331 05-29-2019, 01:44 PM
Last Post: cb1100_dude_imp
  Shock bolt torque HBFL_imp 9 690 04-11-2019, 07:04 AM
  torque specs? Flynbulldog_imp 30 2,111 03-09-2019, 01:13 AM
  Torque specs HBFL_imp 9 1,198 10-25-2018, 02:25 AM
Last Post: HBFL_imp
