Fork seals leaking @19,000 miles on ODO
#41
After using the Sealmate successfully on both CBs, I often wondered how difficult it would be to make my own, when needed. It's just a thin piece of plastic with a hook shape. I always thought a properly cut plastic playing card should do the trick.
Last week I got a chance to test my idea. On the way to Utah for a meeting with Frulk and Django, I noticed that the right fork seal on the CB750 had developed a substantial leak. Bad enough that I could see a large drop of fork oil form behind the tube every 10-15 min.
At one of my gas stops I was able to buy a pack of cards and a pair of scissors. When I arrived at my destination, I cut a card into the general shape of the Sealmate and gave it a try. That's when I found out that not all playing cards are plastic. These turned out to be plastic coated paper and started to come apart after a half turn around the seal. Not to be deterred, I just cut out several of them and cleaned out the seal a section at a time.
Overall, this experiment in roadside engineering was a great success. The fork was sealed up tight and hasn't dripped for 1,500 miles.
[Image: ee3f3fc38c4661f6e5f0d784319e5b06.jpg]
" ... That don't bother me at all
Playin' solitaire till dawn with a deck of fifty-one ... "
Great 'How To", Flyn! Full marks to you.
GO... ROFL
(06-21-2019, 12:42 PM)GoldOxide_imp Wrote: " ... That don't bother me at all
I cut up the Joker and the instruction card for poker. So, at least in theory, I'm still playing with a full deck. Big Grin Big Grin
I stopped "playin' with a full deck" years and years ago...! Confused ROFL
Nicely done Flynrider Thumbs Up Thumbs Up
Great tip Flyn! I nominate the clear plastic packaging that many items from Costco are encased in. Haven't tried it but I am going to save any flat pieces I come across for future reference. Thanks for the tip.
Ben
Have not tried the seal mate but when you use it do you remove the top dust seal and have better access, can see what you are doing or just work it round and hope the edge has collected the dirt and has resumed sealing again?
(06-24-2019, 01:23 AM)max_imp Wrote: Have not tried the seal mate but when you use it do you remove the top dust seal and have better access, can see what you are doing or just work it round and hope the edge has collected the dirt and has resumed sealing again?
Yes, definitely pull the dust seal up. You can't access the actual seal lip unless you do. You will probably find a puddle of dirty oil that you want to clean out first.
When you're done, wipe some WD40 or silicone spray on the fork tubes occasionally. That may help keep dried on mud or dead bugs from causing the problem again.
Yep. In the photo above, the thin screwdriver blade of the multi-tool was used to gently pry the dust seal free and slide it up the tube.
It's also a good idea to run the tool between the fork tube and the dust seal. That'll keep any trapped dirt from migrating down to the actual fork seal.
Pekingduck also makes a good point about cleaning out the area above the fork seal before you start. I used a microfiber cloth wrapped around the point of the screwdriver blade and ran it around the top of the seal. This gets rid of any potential contaminants that have already made it past the dust seal.
(06-24-2019, 12:24 AM)Ben70_imp Wrote: Great tip Flyn! I nominate the clear plastic packaging that many items from Costco are encased in. Haven't tried it but I am going to save any flat pieces I come across for future reference. Thanks for the tip.
Ben
If you're referring to the clear plastic clamshell type material, I think that might be a bit thick and rigid for this application. The tool has to be thin enough to bend easily and conform to the round shape of the tube as you slide it around the seal.
If you do decide to try it, make sure the edges are super smooth. The last thing you want to do is cut or tear the soft rubber seal.
  Oil pan leaking George050994_imp 26 1,935 08-17-2023, 09:34 PM
  Two different fork seals part numbers? misterprofessionality 3 399 08-18-2021, 01:55 PM
  fork overhaul vs. fork replacement? misterprofessionality 20 1,690 09-20-2020, 07:13 PM
Last Post: DBM_imp
  Gas leaking from overflow tubes Edtheguy_imp 11 788 09-01-2020, 02:35 AM
  Leaking fork seals Tezza_imp 33 2,112 08-04-2020, 10:34 PM
  Help with Master cylinder seals any help please dsan1964_imp 10 662 10-30-2018, 11:32 AM
Last Post: dsan1964_imp
  need help quick - oil leaking DJS_imp 32 1,845 08-24-2016, 02:04 AM
Last Post: Riko_imp
  slowly leaking - wondering if I own a lemon CB1100 Riko_imp 10 700 06-21-2016, 03:37 AM
Last Post: Riko_imp
  Leaking Fork Seal? linuxology_imp 16 1,107 05-03-2016, 01:08 AM
Last Post: aschem_imp
  Oil Change 2700 miles CIP57_imp 48 3,479 08-15-2014, 10:41 PM
Last Post: Pterodactyl_imp
