Two different fork seals part numbers?
When checking for replacement fork seals on the web, I found two different part numbers for a 2014 Honda cb1100. Can anybody identify the difference between these two? Why are there two?
https://www.partzilla.com/product/honda/...8da7e3342f
(08-18-2021, 12:56 PM)misterprofessionality_imp Wrote: When checking for replacement fork seals on the web, I found two different part numbers for a 2014 Honda cb1100. Can anybody identify the difference between these two? Why are there two?
If you notice the part numbers are essentially the same, what is possible is that Honda changed the part number at some point and the R61 is the old designation, while D81 is new (?) And they still have a batch of seals with old designation in their stock[Image: c8b2b1cf8dc2d345f0576ccfa51c2475.jpg]
'14 CB1100 STD 5 speed
Hm. I guess that means I should get the d81.
Reccomendations for Fork oil besides the OEM reccomendation?
The 51490-MER-R61 fork seals have been superseded, meaning when supplies run out, the 51490-MKA-D81 will be used. Exact reason unknown, possibly engineering reasons, supplier availability problems, or simply cost.
With Honda, every part has a unique number that is never really changed - it is tied to a blueprint. When a part is obtained from a different supplier, or a material or design spec is changed, the part number is also changed.
Take for example a frame - if one weld is made longer/shorter or a 6mm hole needs to be 7mm, the part number (usually the last 3 numbers) is changed.
That particular fork seal 51490-MKA-D81 is used on almost all the street bikes with 41mm forks, from 300cc to 1300cc.
  Left Side Crankcase Gasket Part number. jbird06_imp 1 339 03-26-2024, 08:56 AM
  Fork seals leaking @19,000 miles on ODO Frulk_imp 64 5,126 12-26-2023, 10:11 PM
  Air filter options - W/ Part #'s PowerDubs_imp 10 960 09-21-2022, 04:02 AM
   Ticking noise from top part of engine Kingkong_imp 40 2,923 03-18-2021, 01:22 AM
  fork overhaul vs. fork replacement? misterprofessionality 20 1,886 09-20-2020, 07:13 PM
Last Post: DBM_imp
  Leaking fork seals Tezza_imp 33 2,400 08-04-2020, 10:34 PM
  Correct part number for front brake pads Frulk_imp 7 663 02-18-2020, 08:06 AM
Last Post: iamheero_imp
  Help with Master cylinder seals any help please dsan1964_imp 10 762 10-30-2018, 11:32 AM
Last Post: dsan1964_imp
  2017 Factory Service Manual Part 2 dave 12 1,004 10-02-2018, 10:10 AM
  Name that part R748_imp 30 2,041 07-02-2017, 01:33 AM
Last Post: Retsel_imp
