Drain Plug New Oil Seal
#31
Sometimes you forget to get one when you get the oil and filter, and only realize it when you are back home and already started to oil change. Not every parts counter guy includes whether it's free or not it if you don't ask for it.
If you're ever going to undertorque something, it should be the drain plug. In factory finish, the '14 DLX crush washer had almost no discernable indentation and the drain bolt spun off fairly easily. Re-used the washer, moderately hand tightened the bolt and replaced the washer next time. Check the oil level frequently. I've got a supply of a half dozen or so of those washers so it doesn't hurt to change 'em whenever the the feeling is it's needed.
  NGK spark plug options Jonnyteabag_imp 6 615 08-05-2026, 11:35 PM
Last Post: JRD
  Booster Plug on an RS TheLegend 6 484 04-22-2026, 06:31 AM
Last Post: TheLegend
  What is this plug? MagnaRider 7 686 02-13-2025, 03:39 AM
Last Post: MagnaRider
  Spark plug socket. Jgarciajr40_imp 5 557 09-11-2023, 10:40 PM
Last Post: Jgarciajr40_imp
  spark plug caps alexzanutto_imp 3 394 01-29-2023, 06:21 AM
Last Post: artashline_imp
  spark plug help, please !! The Gecko_imp 10 774 10-08-2022, 12:22 PM
  Another source for plug-in LED flasher unit. FLYTYM_imp 7 628 01-31-2022, 09:53 AM
  Oil Drain Plug Washer Size Tev62 14 1,029 11-18-2020, 06:29 PM
Last Post: jtopiso_imp
  Fuel Tank overflow drain tube. zirconxi_imp 11 861 05-29-2020, 11:36 AM
Last Post: LakeWylieJoe_imp
  Draining oil from Airbox drain hose. Frequent Oil accumulated. zirconxi_imp 17 1,103 11-27-2019, 09:17 AM
Last Post: jimgl3_imp
