Drive chain replacement time, probably.
#31
(06-01-2016, 02:48 AM)Lord Popgun_imp Wrote: Well, you would need a chain breaker and a staking tool for the master link rivets. And hopefully a service manual for the proper staking of said rivets.
Harbor Freight carries a cheap chain breaker that worked fine for the last chain I replaced. I think it's $14 bucks.
Cycle Gear among others offers up inexpensive chain breaker and pinner.
What you don't want to do is lay out the old chain next to the new one and then cut as the old chain stretches; you want to count links.
(06-01-2016, 11:00 AM)Rboe_imp Wrote: Cycle Gear among others offers up inexpensive chain breaker and pinner.
Measure twice, cut once.
>60: measure twice, think, 'why did I do that?' Remember. Measure twice more, repeat.
Ideally what you want to do is get a chain with the correct number of links from the factory (then count the links). Fortunately, both of my CBs require 110 links, which is commonly available from most manufacturers. I haven't had to cut a new chain in many years.
  CB1300 headlight bucket replacement spechg 5 386 03-16-2026, 10:12 AM
  HISS Key replacement UK Davidjill_imp 12 999 01-19-2026, 05:09 AM
  Rear brake pad replacement LongRanger_imp 39 3,639 05-03-2025, 10:45 AM
Last Post: Delphisa
  New speed meter replacement ACE_IRA_imp 3 526 02-13-2025, 06:25 AM
  Fork Pipe replacement suggestions danieljrmurray_imp 3 508 10-09-2023, 02:31 AM
Last Post: danieljrmurray_imp
  Fuel filter replacement Mafd2_imp 36 2,907 02-11-2023, 01:54 AM
  Replacement Battery dave 54 4,089 02-04-2023, 12:41 PM
  Front drive chain sprocket wear 1970Cadillac_imp 15 1,233 11-29-2022, 07:49 AM
  2013 replacement wheel Randy B 8 786 11-13-2022, 10:32 AM
Last Post: Randy B
  Clutch replacement advice misterprofessionality 31 2,504 06-11-2022, 05:51 PM
