Which wire to tap for GPS power?
#31
(07-18-2016, 02:25 AM)Lord Popgun_imp Wrote: Yes, but riding at night, no headlight, could be a bad thing. The fuse stops current flow by interrupting the current path. I wouldn't lose any sleep over it, just a consideration.
Edit: Rico, Sometimes the internet makes it hard to tell what we are talking about. I've thinking that you mean the connection you (or the dealer) added has its own fuse. That would be a good thing.
I added a power connection to my headlight accessory plug Saturday and the lead has its own 7.5amp fuse. So I left it so hopefully if something goes wrong, it will pop instead of the 10amp fuse.
yep, thats what I meant, also, the GPS device (tomtom rider) has its own build in fuse, so the dealer didn't have to add one.
(I think he didn't after I told him about the fuse)
But my point was actually that its better to hard wire from anything else than from the battery directly.
I I've read hardwiring something to the battery is not ideal because you would/could draw from the battery even if you switch off the engine/bike.
For instance when your GPS is still on.
When connecting it to something like your lights you know the GPS won't draw power even when switching the engine off because your lights won't work.
Also the newest systems automatically shut down if the power is shut off as well, but I'm not sure if this is also the case if you hardwire it to the battery directly.
Thus the mechanic (like most mechanics I know of) hardwire a GPS system to the headlights.
I also assume they choose for the headlights since headlights are located much closer to the GPS than the battery wich is located further back and thus needs for longer cables going through the length of the bike etc.
Rico, that makes sense. In our case we have 2 accessory connectors that also could be used and are only powered with ign. on. I doubt your dealer knew that. But all is well and we can go riding!! Smile
You can't go riding, popgun. We might need you round here! Big Grin
  m-txd/rxd wire (white) ecu to instruments communication deano 28 1,991 01-23-2026, 12:48 PM
  M-TXD/RXD wire is disconnected deano 1 205 01-01-2026, 06:40 AM
  GPS power cable The Gecko_imp 10 1,059 10-06-2023, 12:40 AM
Last Post: suhawk305
  Has anyone installed a power commander in? Doug Shepard_imp 3 519 08-10-2023, 07:20 AM
  Power source for oil indicator led norton1974_imp 1 290 12-31-2022, 10:07 AM
  Power Commander V question HBFL_imp 1 267 08-23-2022, 05:41 PM
Last Post: jtopiso_imp
  Wire Colors for Signals, Tail Light RedRoevr_imp 10 815 05-01-2022, 06:23 AM
  Power Commander Tune Maps. mvk24_imp 43 3,230 01-03-2022, 08:16 AM
Last Post: SoCal CB1100_imp
  2010 model Power Commander alternative? 83NZA_imp 7 666 08-03-2021, 02:04 PM
Last Post: Aussieflyer
  Transmission power routing and speeds LakeWylieJoe_imp 6 676 01-10-2021, 10:30 AM
Last Post: jimgl3_imp
