Spark Plugs
#31
Did you remove the tank?
Sent from me......
(05-21-2016, 05:50 AM)kennyw_imp Wrote:
(05-21-2016, 05:08 AM)MMC_imp Wrote: What's the best way to get to the inner plugs? I've got the slim socket...
Sent from me......
1/2" drive ratchet and 1/2 to 3/8 adapter should put you below the frame and over the valve cover.
Or was that 3/8 ratchet with 3/8 to 1/4 adapter? Now I may need to run down to the garage and double check.
Sent from me......
Or was that 3/8 ratchet with 3/8 to 1/4 adapter? Now I may need to run down to the garage and double check. Must be 3/8 to 1/4.... Yep, that's it. Done! Thanks.
Sent from me......
(05-21-2016, 06:19 AM)The ferret_imp Wrote: Toro..do you have the one in post 1 of this thread? You can use a 13 mm box end wrench, 14 mm box end wrench or 1/4" drive ratchet I believe
Thanks for the hint. I do have both metric wrenches and 1/4 drive ratchet but most of my spark plug sockets are fairly thick walled and may not fit too well. I was just glad for the heads up on this and will see if what I have will work before starting the job. I am not close to needing plugs but may pull one just to see how the color looks.
One trick that can work in a pinch is if you do not have the proper spark plug socket is to use a deep socket of the correct size to unscrew the spark plug then use a long magnet to pull it out. When threading it back in use a piece of fuel line or rubber hose to lower it down in the hole and get it started. The nice thing about using the rubber hose is that it will slip and prevent cross threading if the plug does not start threading correctly. Then just use the deep well socket and torque.
The plugs are $10.25 on Amazon and the tool is $17.
I ordered the stuff so I have it ready at 8k but that's gonna be a while anyway. I'm still about 1k.
That is a great price for these plugs.
That's why I figured I better order now. Who knows if they'll have them available when I need them.
***EDIT*****
There is some question about whether these are correct or not. They have a different washer than the Honda-specific version. I would not order until it is determined if these will work
In case anyone is in the market, an Ebay seller with a lot of good feedback (not me) sells a 4-pack of these for just a shade under $26.00 including shipping:
http://www.ebay.com/itm/4-pc-4-x-NGK-Sta...1676142595
Not sure if this is a special deal or this is the price that these plugs have finally settled into, but I'm going to go ahead and buy a set to keep in my "someday" parts bin...
Wow that's like $6.50 each and free shipping. I already have a set in stock but getting ready to use those, so I'm in for a set. Thanks for the tip Shinchan
I know, it's getting down to the "normal" NGK plug prices...
I wonder if in 40 years these weirdo plugs will be rarer than hen's teeth.
(07-11-2016, 04:38 AM)The ferret_imp Wrote: Wow that's like $6.50 each and free shipping. I already have a set in stock but getting ready to use those, so I'm in for a set. Thanks for the tip Shinchan
  NGK spark plug options Jonnyteabag_imp 6 616 08-05-2026, 11:35 PM
Last Post: JRD
  spark plugs after 70.000 Km DAC 16 1,514 12-23-2025, 10:15 AM
  'Factory' high performance spark plugs PowerDubs_imp 17 1,474 10-23-2024, 02:50 PM
Last Post: rtmoto1
  Spark plug socket. Jgarciajr40_imp 5 558 09-11-2023, 10:40 PM
Last Post: Jgarciajr40_imp
  spark plugs NGK LMAR8A-9S louied_imp 1 327 06-27-2023, 01:19 PM
  2017 CB1100EX Accessory Plugs TXBikerGuy 13 1,128 06-24-2023, 08:27 AM
  spark plug caps alexzanutto_imp 3 396 01-29-2023, 06:21 AM
Last Post: artashline_imp
  spark plug help, please !! The Gecko_imp 10 774 10-08-2022, 12:22 PM
  Spark Plugs HondaJon_imp 105 7,022 03-19-2022, 08:53 AM
  CB 900C Custom Spark Issue goatman64_imp 3 361 11-27-2021, 07:11 AM
