Real world benefits of the slipper assist clutch
#31
How much for the all parts alone??
Pete- last I checked, if bought from Babbits Online and using the code Eddie12 or OEM10 the parts were less than $250.
Here is the 14 & 17 chart. The crankshaft and cases are the same. I can't tell from the picture what you need to do- but at least based on all the part diagrams and #'s there is no reason whatsoever it should not work if you have the right parts in the right order.
14- https://www.babbittsonline.com/oemparts/...a5e/clutch
17- https://www.babbittsonline.com/oemparts/...366/clutch
Keep in mind the diagram reference #'s don't carry over. You need to compare actual part #s, as well as quantities on stuff like the clutch plates.
I've love to be there to help.
He, he, he..will not dig in my OEM '14 CB just to use one finger to apply clutch....waste of time and money....meantime I can easily clock 200 kms
**Mine is so smooth = no need for any better...
*** Smell trick from Honda, however I might be wrongHuh
**** The bottom line for me is: even if Honda Japan wanted to install parts/labour for free, I would not need this type of improvement. I like if the life is a little bit complicated, so I have to challenge it daily, stay the course and always be on the top.
Good luck to all who want to dig in.Thumbs UpSmile
Josh, how is recovery progressing...when will you Biker again??? Thumbs UpSmileThumbs Up
My 2017 clutch is a little lighter to pull than my 2013 and 2014 but it is not a problem for me at all : both still very light.
The slipper part is nice when down shifting but again for me not a deal breaker.
I have just ordered the 2017 Honda service manual.
Hoping it will me figure this out.
The real world benefits of a slipper clutch is to simply reduce initial engine braking when downshifting for deceleration. IMHO this may be beneficial for very high RPM, extremely oversquare bore motors, but see little benefit on the CB.
(01-19-2018, 03:17 AM)Ulvetanna_imp Wrote:
(01-19-2018, 03:08 AM)SportsterDoc_imp Wrote: The principle purpose of a slipper clutch is to reduce engine braking and increase rear tire control, especially if that engine braking is done abruptly and while heavily applying the front brake.
An easier pull is a side benefit.
Canyon running with my Sportster 1200 Sport would chirp the rear tire when I got lazy (not lightly blipping the throttle) on downshifting before a turn.
A slipper clutch would reduce that, but I've not had that issue with the 2014 CB1100. Nevada does not have the canyons that I enjoyed in SoCal, but Deer Creek Road (NV highway 158 in the Spring Mountains) is a smooth run on the CB1100.
Think of a slipper clutch as partially pulling the clutch lever when abruptly backing off the throttle.
In the broadest sense, yes.
But in the specific technical aspects of performance, engine braking is something that is determined by the tuning of the ECU through fueling adjustments.
Motorcycles today, especially high-performance racing engines, can be very precisely tuned for a variety of engine braking performance parameters.
For example, a WSBK bike can be tuned to increase or reduce engine braking for every turn on the racetrack. And that braking is adjusted automatically in real time by GPS location provided by satellite tracking.
Nicky Hayden crashed once because the GPS signal failed at a critical moment and his bike didn't have the engine braking he expected.
I just bring this up because it's an important point; engine braking can only occur if the engine is actually connected to the drivetrain.
A slipper clutch disconnects the engine and drivetrain until equilibrium is restored. Experienced riders proficient at shifting will likely never have the slip feature activate. If it does activate, even for a really bad shift, it'll only be for a few milliseconds, just long enough for the RPMs to again match up.
But as the post above indicates, the slip feature can partially disengage, provide some engine braking while still preventing serious rear skid.
But to be clear, the slip feature is like an invisible hand on the clutch; its purpose is the pull in the clutch a bit if you don't.
That is not the case, as Henning explains in the video.
"The whole idea behind a slipper clutch is that it prevents engine over rev and rear-wheel chatter, and helps keep the rear suspension working properly during hard engine braking caused by aggressive downshifts."
A slipper clutch will never, ever activate if the throttle is merely backed off. The deceleration force is nowhere near sufficient enough to separate the clutch plates. This would be a serious control issue because the clutch would suddenly re-engage if the throttle was applied, leading to a lurch. Its design function is to limit rear skidding during a bad, mismatched downshift only.
Henning misrepresents the function of these clutches when he says "no rev-matching required". A slip-n-grip clutch by no means can seamlessly match the revs for a rider in a transparent way. It doesn't remove the responsibility for riding well from the rider. You will darn well know when the clutch is being released by that "invisible hand" and it functions more like a light switch. Certainly, the slip-n-grip is nothing like a seamless, "no-brainer" kind of feature. It's like a crude version of ABS, it'll pull in the clutch for you if you screw up. It's not an "intelligent" feature, it's mechanical, and subject to very significant hysteresis and is not anything like "predictable".
Compare with intelligent ABS systems, which can seem "seamless" and transparent. Not the same thing at all.
I emphasize this point because, just as with ABS, if a rider thinks he or she can get away with not learning to shift, and the the slip-n-grip is just gonna save his/her bacon, they're gonna be very shocked and appalled when they crash because they think the system will prevent all possible losses of control due to poor downshifting technique. Think about what happens if you suddenly pull in the clutch just after chopping the throttle in a turn.
You lose engine braking and will run wide. A huge botch in a downshift will result in just this kind of reaction from a slip-n-grip clutch until it stabilizes.
That is not the case...
Trying to understand your wording versus mine.
Yours: "the slip feature is like an invisible hand on the clutch; its purpose is the pull in the clutch a bit if you don't."
Mine: "partially pulling the clutch lever when abruptly backing off the throttle"
One is an over-running clutch and the other is manual, whether only backing off at very high RPM or actually downshifting.
(09-28-2018, 12:03 AM)SportsterDoc_imp Wrote: The real world benefits of a slipper clutch is to simply reduce initial engine braking when downshifting for deceleration. IMHO this may be beneficial for very high RPM, extremely oversquare bore motors, but see little benefit on the CB.
...aaaaaand stop the rear wheel from locking up when you ham-fist a downshift. (the actual real-world benefit of a slipper clutch)
You don't need to back off the throttle for the slipper function to kick in (in fact you couldn't activate it this way if you tried), you need to down shift without matching revs. It only kicks in when the rear wheel speed is different from the engine speed, which is NEVER the case when not actually downshifting. Simply dumping the throttle from high RPM doesn't induce the slipper function.
That is the initial engine braking unless the throttle is applied during the downshift.
My comments are a response to a difference in wording, not understanding.
A better explanation...sometimes I try too hard to keep things brief.
I do understand overrunniing clutches.
I was a Formsprag distributor in the mid eighties.
https://www.formsprag.com/
The point I was attempting was that if one is not prone to lazy downshifts, there is little benefit.
I will admit that when I did a lot of canyon riding, circa 2005, in SoCal on my 2002 Sportster 1200 Sport, tire wear increased as the day got longer (typical 250 mile rides...from progressively lazier downshifts...more than from acceleration. It also increased primary chain adjustments!
The rotational mass is lighter as well.
Unsure of how much, but never a bad thing.
If your skills are dialed, and you don't make early/aggressive downshifting mistakes, then why would you need a slipper clutch?
  CLUTCH FLUID CHANGE SUPERCRUZ_imp 15 1,175 12-24-2025, 11:14 AM
  Replace clutch Lever Davidjill_imp 10 930 02-06-2025, 01:27 AM
  Clutch Plates finally going? misterprofessionality 12 1,032 11-22-2024, 07:49 AM
  Clutch fluid change CB1100@2013: photos valkyrie_rider_imp 0 234 02-13-2024, 10:27 AM
Last Post: valkyrie_rider_imp
  Clutch Fluid Wagonpeddler_imp 32 2,413 06-14-2023, 08:09 AM
Last Post: bvictory_imp
  Clutch Not Working Henrik_imp 7 613 04-24-2023, 06:43 PM
Last Post: Henrik_imp
  Clutch pull mpuhl_imp 4 483 02-21-2023, 10:48 AM
  Clutch slave cylinder gasket Maturecheese_imp 3 366 01-27-2023, 12:33 AM
Last Post: Maturecheese_imp
  brake & clutch adjusters The Gecko_imp 10 768 11-25-2022, 08:47 AM
  Clutch Lever Full Engagement odelegacy_imp 41 2,649 10-28-2022, 09:27 PM
