2017 CB1100 EX FUEL CAPACITY
#31
(02-06-2018, 03:00 AM)SportsterDoc_imp Wrote:
(02-06-2018, 02:53 AM)The ferret_imp Wrote: 60 minutes for editing. That's generous. Another forum I am on has a 3 minute time limit for edits before you have to contact the administrator. You really should be able to figure out what you wanted to say in an hour. After an hour you can contact a moderator or administrator to edit the post for you. As far as deleting a post, due to an issue in the past, only a moderator or adm can delete a post. If you want a post deleted, you must pm Guth, Cormanus or myself and we can take care of that for you, as long as it's doesn't upset the flow of conversation.
For casual posts, yes.
For technical posts, I should delay posting and finish research, first.
If the issue is already solved, then no need to post.
You can always put your post in a Word file and save until you get everything you need, then copy and paste to the forum.
..... or I think we can "Safe as Draft" .... this is what I do...and update any time later...
pb
Don't you blokes with these new-fangled post 2013 CB1100s have a trip computer that tells you how many miles you have left in the tank? I thought you did? I also recall that Ferret and others have commented on its accuracy. Why not also review the thread on [url=http://cb1100forum.com/forum/showthread.php?tid=11741]Noroomtomove's First Law of Motion and Fuel Consumption which will give you a handy tip or two on how to work out on any given occasion how much fuel you have left in the tank and how far it is likely to take you. The reserve light on my bike starts flashing at different mileages depending on a whole range of factors, like wind, riding style, temperature. What matters is how much juice you have left after how long and how far it will take you on that occasion.
Given that my riding style means I don't seem to go near the sort of MPG the Ferret and Noroomtomove are capable of achieving, my CB is going to run out of gas long before theirs. That's what I want to be able to work out.
By the way, NRTM's formula has given me a great deal of comfort. Today I happily rode more than 30 kms past the point where I would normally have filled up and achieved a personal best on kilometres ridden before filling up. I still had at least a couple of litres left so could have gone further.
(02-07-2018, 10:31 PM)Cormanus_imp Wrote: Don't you blokes with these new-fangled post 2013 CB1100s have a trip computer that tells you how many miles you have left in the tank? I thought you did? I also recall that Ferret and others have commented on its accuracy. Why not also review the thread on [url=http://cb1100forum.com/forum/showthread.php?tid=11741]Noroomtomove's First Law of Motion and Fuel Consumption which will give you a handy tip or two on how to work out on any given occasion how much fuel you have left in the tank and how far it is likely to take you. The reserve light on my bike starts flashing at different mileages depending on a whole range of factors, like wind, riding style, temperature. What matters is how much juice you have left after how long and how far it will take you on that occasion.
My EX has a trip computer. If I remember which of the buttons I am suppose to push twice, it will display some information. Hopefully before I run off the road trying to access it.
Then the sun usually makes it unreadable. So If I lean forward and put my glove over it, I may be able to read it. Hopefully before I run off the road trying to steer the bike with one hand.
I have 100 maps which I use to set a route for my day ride. Each of the maps has the distance of each leg. I know I average 21 kilometers per liter on my EX. So I plan to my gas stops for 250 to 275 kilometers.
The maps also have the time required for each leg. So I can plan when and where I will stop for breakfast, lunch, and afternoon break. If possible I will stop at a place for lunch that also has a nearby gas station.
That way I don't have to worry about running out of gas or running off the road pushing buttons and trying to read some tiny and hard to read information.
These new fangled devices are like the rear view camera on my Impala LTZ. Great when you are in the shade of the garage, provided you remembered to clean the slush, road salt or dust off the lens before you pushed the starter button. But totally useless when you back out into the glare of the sun. Fortunately cars still have three mirrors.
Can you tell winter makes usually friendly and polite Canadians GRUMPY! Angry
I don’t envy you winters like yours. I’d be very grumpy indeed!
The numbers on the trip meter (which is all I have) are easy to read in nearly all conditions. Sometimes simple is good.
In the spring I will run a fuel capacity test on my second day ride.
I average 21 kilometers per liter on my 2017 CB1100 EX. If the tank holds 16.8 liters as the Owner’s Manual shows, the maximum calculated fuel range should be (16.8 L x 21 KPL) approximately 350 kilometers.
According to the Owner's Manual the last segment of the gauge should flash when there is 3.6 liters of gas left in the tank. So I should be able to travel about (13.2 L x 21 KPL) 275 kilometers before the last segment of the gauge flashes. If it flashes before that, I will know Honda Canada was right about the tank holding 14.6 liters and re-fuel.
It is does not flash until 275 kilometers, with 3.6 liters of fuel I should be able to travel another (3.6 L x 21) 75 kilometers. But I am not going to push my luck. Push being the operative word.
According to the Owner's Manual the last segment of the fuel gauge should go blank when there is 1 liter of fuel left. So I should be able to ride about (2.6 L x 21 KPL) 55 more kilometers before that happens, and still have enough fuel to find a gas station within the next 20 kilometers. If that happens I know the tank holds 16.8 liters.
i dont know...but in the owner manual you can read how big is the total tankvolume....i hold this 14.6 on the canadian page as a writing error..
has not the old "standard" just this 14.6l ?
and i dont belive honda makes extra realy 2 versions of a edgeless tank for the 17' models...
every pic/ (tank)-desing that i saw until now from a 17' model looks for me identical
Nortoon, if you're planning your fuel stops for between 250 and 275 kms, your fuel tank must be bigger than 14.6 litres. Although noroomtomove has run his 14.6 litre tank dry in the region of 300 kms on a couple of occasions, there's no way I'd plan on allowing more than 250 kms between fuel stops. Even then I'd be nervous.
I'm confident my tank is 14.6 litres and the wee red flash has been known to start before I've gone 200 kms—usually only in city traffic or, for some reason, when I've had fuel stabiliser in it. More usually, though, it starts flashing between 200 and 220 kms. If it starts at 200, I'll confidently go to 230 and a bit before refuelling, although I usually put around 10-11 litres in it. Pterodactyl, with whom I've ridden a good few kilometres, has a similar fuelling experience.
My manual says I have 3.5 litres left when the light starts flashing.
But then, I draw your attention to the curious incident of VLJ's refuelling, reported [url=http://cb1100forum.com/forum/showthread.php?tid=12158]here.
One final thing. Either Honda Canada or Honda US is wrong. Honda US says [url=http://powersports.honda.com/2017/cb1100/specifications.aspx]here that the fuel capacity of the 2017 EX is 4.4 gallons (or 16.6558 litres). I don't know that I'd rely on it, but using Google Chrome with its in-built translator tells me the Japanese web site claims 16 litres for the EX and RS and 14 litres for the standard.
by the standard i dont know of course i have only a DLX......but there if you mean its already full....you get with a lot patience swallow for swallow more in....mabye until 1/2 l more. by the end........at the 17' model is that this effect not that big ...but...
All this talk of fuel capacity might prompt me to do something I've considered for years, which is to strap a one-gallon plastic gas can on the back and run the bike out of gas to learn its true usable capacity. In my experience, most (but not all) vehicles are very conservative with their gauges and low fuel lights, for the obvious reason that manufacturers don't want unhappy owners running out of gas.
But I find it silly to feel the need to refuel a small (less than five gallons) tank when there may be two gallons left. I just sold a Moto Guzzi with a reputed tank capacity of nearly five gallons. The stupid thing only returned 37 or 38 miles per gallon (and yes, it was stock and perfectly tuned), and the low fuel light turned on consistently at about 133 miles. I could only stuff 3.2 or 3.3 gallons in it . . . so what was the usable capacity?
And I had a 2009 Harley Ultra (stock, like all my bikes) that allegedly had a six-gallon tank. It also had a gauge and a "miles remaining" calculation that was selectable on the dash. Once the low fuel lamp illuminated, the display switched and started the countdown. I was on I-77 in Ohio early one morning, approaching the New Philadelphia area; the countdown was in progress . . . 25, 20, 15 . . . then "LO". (Note: When it says "LO", believe it!) I knew where the gas station was (the BP) and could actually see the sign in the distance. Well, the near-900 pound SOB started chugging. Terrific, at 70 mph with traffic. I eased off the throttle and hoped. Made it to the exit, but there was a traffic light at the bottom. Please, please, be green . . . It was, and I rolled into the station on the fumes. I stood there and nursed every bit of gas into the tank that I could. It took 5.48 gallons. Not six. Irritated me to no end. If you claim six gallons, the damn thing better take six. POS.
On the other hand, I had a similar experience with my old Road King near home. It was late autumn, so time to put the King away for the winter. I knew it was low on gas, but the station was just one exit down I-70. Yep, started chugging on I-70. Pulled into the station and filled it. It took 4.97 gallons. That one was a true five-gallon tank, as advertised.
My BMW R1100RT was advertised as having a 6.6 gallon tank. But one day I ran it up over 300 miles on a tank and put 6.8 gallons in it . . .
  Workshop Manual and Parts Book 2017 on CB1100's sprint 5 579 01-13-2025, 06:10 AM
  CB1100 SA-E 2017 Battery Davidjill_imp 1 276 08-01-2024, 02:33 AM
  CB1100 fuel tank upgrade johnnyH_imp 3 443 03-13-2024, 01:31 AM
   Actual Oil Capacity of the CB1100??? Yata-Garasu_imp 43 3,117 07-26-2022, 11:26 AM
  FORK FLUID CAPACITY Enzofour_imp 6 549 01-29-2021, 06:19 AM
  How to adjust the front forks on a 2013 CB1100 and a 2017 CB1100EX. michael1954 13 945 02-28-2020, 07:56 AM
  2017 cb1100 power commander V AFuglyDuckling_imp 2 272 04-10-2019, 01:56 PM
  Engine oil capacity emullick_imp 1 222 01-03-2018, 10:45 AM
  2017 CB1100 RS - Heated grips cable sleeve hdvalente_imp 2 251 05-21-2017, 07:17 AM
Last Post: hdvalente_imp
  CB1100 2017 - How to have turn signal always on mrbi0_imp 12 975 03-20-2017, 09:09 AM
Last Post: AzBob_imp
