CB1100 2017 - How to have turn signal always on
Hi everyone,
Last week i've went to dealer, left my '14 CB1100 and brought the '17 (side note: absolutely loving it!).
I've seen some japanese videos of the bike with the orange turning signal light always on. A little dimed, not the actual turning light. I guess similar to the '16 Africa Twin for instance.
As i understand, in some countries that's mandatory and I don't think there will much of changes in the CB so, I wonder if this is something simple to change in the electricals...
(never thought about it in the '14 model until now)
Anyone ?
The front (amber) lights in the US function as running lights ( always on) and turn signals ( flash). THe rear light ( red) only function as turn signals ( flash).
Is that what you are asking?
(03-13-2017, 06:30 AM)The ferret_imp Wrote: The front (amber) lights in the US function as running lights ( always on) and turn signals ( flash). THe rear light ( red) only function as turn signals ( flash).
Not quite Wink
You see this video: https://youtu.be/ZnEZdh0LlfI?t=1m33s
It starts with a bike running and light from the turn signals.
Just rode yesterday with a friend of mine that has an Honda Africa Twin and at night I can see the headlight and also the turn signals light. When he turns, they are brighter and they flash.
Mine has just the headlight and the turn signals only when I turn, they're not always on.
Did I manage to explain it better ?
Yes, apparently in Portugal, it is not required to have running lights.(amber turn signals on at all times)
(03-13-2017, 07:54 AM)The ferret_imp Wrote: Yes, apparently in Portugal, it is not required to have running lights.(amber turn signals on at all times)
But I want to ! Tongue
Increases visibility when riding at night (and I think it's quite stylish also Wink)
Any idea how ?
Bet popgun could figure it out. He's an electrical savant
I don't know about a savant, but I an an electronics tech! Mostly on radar nowadays. I could send Mrbi0 a US wiring diagram and he could compare it with his version. It probably isn't a big change and hopefully could be easily done. Or he could send his I could take a look.
Apparently different countries got different wiring. Or at least some did. From corresponding with a Russian member the two of us figured that out pretty quick.
Edit to add: I see in another thread that you have a new 2017! Congrats! I would like to see the wiring diagram for that. It is likely pretty much the same, but it does have LED lights too, so there may be some differences.
(03-13-2017, 09:37 AM)Lord Popgun_imp Wrote: I don't know about a savant, but I an an electronics tech! Mostly on radar nowadays. I could send Mrbi0 a US wiring diagram and he could compare it with his version. It probably isn't a big change and hopefully could be easily done. Or he could send his I could take a look.
Glad to help and share the wiring with you to see if we can figure it out Wink
Just so I understand, does the US wiring have the "always on" feature ?
Yes. The front signals are always on. They blink when you select left or right turn signals or emergency flasher.
I took a quick look at the wiring diagram and all that is controlled by the Turn Signal-Position Relay. It has two 4 pin connectors
The bulbs are connected to chassis ground on one side and the other goes directly to the relay. Switch inputs also go there to tell it to flash the signals or blink all the lights if the emergency flasher is selected.
It MAY be as easy as swapping in a TurnSignal-Position Relay from a US model, or a European model that has front signals on all the time. Would have to see a diagram for your bike.
(03-13-2017, 11:05 AM)Lord Popgun_imp Wrote: Yes. The front signals are always on. They blink when you select left or right turn signals or emergency flasher.
How would you compare your new 2017 to your 2014?
Suspension and exhaust would seem to be the obvious ones but what say you?
Tks
John
  Rear indicator (Turn signal) relocation bracket 2013 model AndyBeeMD 15 1,551 08-16-2025, 05:01 PM
Last Post: bflint
  Workshop Manual and Parts Book 2017 on CB1100's sprint 5 617 01-13-2025, 06:10 AM
  CB1100 SA-E 2017 Battery Davidjill_imp 1 297 08-01-2024, 02:33 AM
  Pictures of OEM Rear turn signal mount Houndwheels_imp 8 793 09-12-2023, 10:28 AM
Last Post: Houndwheels_imp
  removing rear turn signal modmaster_imp 12 1,060 04-20-2023, 10:17 AM
  After market turn signal on CB 1100rs 2018 not working Saltani_imp 6 563 12-08-2022, 09:24 PM
Last Post: leung_imp
  Turn Signal Switch and Horn Button Locations pekingduck 26 2,033 07-12-2022, 08:04 PM
Last Post: tommymck
  2013 turn signal replacement RF(OEM) casey66_imp 17 1,354 01-15-2022, 01:31 AM
Last Post: Bazbro_imp
  Turn Signal Malfunction billyfinchapel_imp 5 580 05-04-2021, 01:51 PM
Last Post: billyfinchapel_imp
  rear signal assembly cj599_imp 14 1,030 03-19-2021, 08:14 AM
Last Post: cj599_imp
