 Actual Oil Capacity of the CB1100???
The manual claims the CB1100 require 4.9 liters of oil. That comes out to 5.177 quarts, which is obviously wrong.
There was another thread asking about this, but I never found the answer to the question, and it was an old thread. So I'm reasking the question.
What is the actual oil capacity of the CB1100?
I prepared my 5.177 quarts of oil. I removed the filter and drained the old oil.
When I went to refill, after putting in the first 4 quarts, the oil glass was completely full, all the way to the top. In other words, it was over full.
I didn't add the remaining 1.177 quarts of oil, but I saved it as I thought that after running the motor for a while, it might suck up the extra oil... It did not.
A week after the oil change and now I have oil seeping from around the fill cap.
Then I remembered. The same thing happened last year after I had the oil changed at the Honda dealership. Even the dealership doesn't know how much oil this thing takes!
At the time I thought I had a faulty fill cap gasket, so I ordered a new one, removed some of the excess oil with a large gauge straw, and that seemed to fix the problem.
A year later and with a fresh oil change, now the gasket is leaking again.
I'm 99% certain that the fill capacity of 4.9 liters is a typo. Even 3.9 liters would be 4.12 quarts, and my bike is over full with 4 quarts.
My best guess is that they meant to write 3.9 quarts, but accidentally typed 4.9 instead of 3.9, and then compounded the problem by writing liters instead of quarts.
I'm going to try and remove about 0.1 quarts using a Boba/Slurpee straw, and see if I can line it up in the sight glass.
I'll post back later after I get the sight glass lined up.
You are mis-reading the manual. My 2013 owner's manual on page 122 says, "After draining . . . 4.0 US qt (3.8 liters)"
Think you may have got the liters and quarts backwards.
Covered many times, but—
From the service manual: After draining—3.8L (4 US qts, 3.3 Imp qt)
After draining/filter change: 3.9L (4.1 US qt, 3.4 Imp qt)
After disassembly: 4.9L (5.2 US qt, 4.3 Imp qt)
(*sigh*) Never measured the oil into the CB, just used the looking glass during the last half liter/quart of whatever oil.
(05-18-2022, 11:29 AM)GoldOxide_imp Wrote: (*sigh*) Never measured the oil into the CB, just used the looking glass during the last half liter/quart of whatever oil.
+1
(05-18-2022, 10:30 AM)Lord Popgun_imp Wrote: Covered many times, but—
Ok, but when I changed the filter and drained the oil, 4 quarts still completely fills the sight glass.
Are you folks doing anything special to drain out any extra oil from the cooler?
I just removed the filter and drain plug and let it drain for 15 minutes.
4 quarts is more than she needs...
I would be surprised if it takes more than 3.9 quarts, even when changing the filter.
Fwiw, the 4.9 liter figure I found was for the older 80s CB1100. Details, details!
+1
+1
That is the most accurate way to measure the oil level in your bike, because actual capacity doesn't matter, it's the height in the engine that the oil sits at, so that the oil pickup is continuously covered, but the oil level is low enough so that the spinning crankshaft and various parts aren't smacking into the surface of the oil and creating excess friction and foam.
The only other way to actually calculate the actual capacity is to take a completely dry engine, then fill the pan and oil passageways, and to ensure the oil level is at a 100% efficient level, which, lo and behold, we can see in the ranged oil sight glass of the bike.
Just use the service manual spec as a general guide, and add/subtract volume to your preference.
Leaving an undrained cup or two of old oil in a sea of fresh crankcase oil is not going to have an impact on a civilian motorcycle that gets routine care and maintenance.
GoldOxide's approach works for me.
Fwiw, the 4.9 liter figure I found was for the older 80s CB1100. Details, details! Ah, I was wondering where you got that. An easy mistake to make. Don't obsess on it. There are more important things to spend your time on. Ride your bike and have some fun. Beer Biker
Thanks for all the replies. Next time I will plan on 3 quarts plus whatever it takes to line up the sight glass.
   Rotella T5 10w30 + CB1100 = HAPPY!!! Yata-Garasu_imp 73 6,837 07-12-2023, 01:00 PM
  FORK FLUID CAPACITY Enzofour_imp 6 549 01-29-2021, 06:19 AM
   front suspension oil change CB1100 EX 2015 (23700 kms). recommendations ?. Alfgaxatico_imp 7 654 11-23-2020, 07:34 AM
Last Post: Alfgaxatico_imp
  2017 CB1100 EX FUEL CAPACITY Nortoon_imp 57 3,770 12-09-2019, 01:03 PM
  The actual required services by mileage Streetshark07_imp 5 462 06-29-2019, 07:58 AM
Last Post: SportsterDoc
  Engine oil capacity emullick_imp 1 222 01-03-2018, 10:45 AM
