145$ for the set of rotors on ebay.
#31
(06-25-2020, 04:30 PM)jtopiso_imp Wrote:
(06-25-2020, 01:39 AM)mvk24_imp Wrote:
(06-25-2020, 01:33 AM)IndianRider_imp Wrote: I think most of my bikes had a very slight pad contact spinning on the stand with no drag at all .. seems to be normal
The pulsing may be when the piston doesn’t retract quickly and completely even like it’s supposed to .. the lowest piston is the one usually partially submerged in old fluid and moisture .. or maybe it just needed a good brake flush and bleed
Yea that would be awesome of it's just a caliper cleaning. My front tire was also the worst cupped we have ever seen but it was very hard to notice in my overhead garage lighting where I usually check the bike over. I must have been riding like that for awhile. One of my buddies noticed the cupping when the sun was hitting it from the side and the cups were casting a shadow.. maybe the cupping in low speed decel was also contributing?[Image: 51514d8d266d9c316239ee3abc440370.jpg]
That looks awful!
What brand/make is that tyre? It looks like (maybe only in the picture) the cupping pattern is in perfect sync with the tread pattern, amd if that's the case, my guess would be that tyre construction has been the cause.
That looks awful!
What brand/make is that tyre? It looks like (maybe only in the picture) the cupping pattern is in perfect sync with the tread pattern, amd if that's the case, my guess would be that tyre construction has been the cause. It was the stock BT45s. I went with the metzler Roadtecs this time around.
Never having balanced a tire, how does that balancer work? How do you know where to put the weights? Inquiring minds want to know Smile
[url=https://www.google.ca/search?source=hp&ei=Sfj1XsezM9K1tAak_aS4AQ&q=how+to+balance+motorcycle+wheel&oq=how+to+balance+mot&gs_lcp=CgZwc3ktYWIQARgBMgIIADICCAAyAggAMgIIADICCAAyAggAMgIIADICCAAyAggAMgIIA​DoICAAQ6gIQjwE6BQgAEIMBOgUIABCxA1CzFFinRWDLXWgBcAB4AIABbogBmwySAQQxNi4ymAEAoAEBq​gEHZ3dzLXdperABCg&sclient=psy-ab#kpvalbx=_Vvj1XtLdM5jWtAbFkaOoBw33]https://www.google.ca/search?source=hp&e...bFkaOoBw33
post #28 by pekingduck: I use a Harbor Freight balancer too, but I don't balance them with the wheel spacers in place, I go right up against the bearings. I find the wheel bearings have less friction than the balancer bearings. That's on newer wheels, with fresher grease.
Simple physics
Smile
(06-25-2020, 10:59 PM)Lord Popgun_imp Wrote: Never having balanced a tire, how does that balancer work? How do you know where to put the weights? Inquiring minds want to know Smile
1. So very straight forward, you spin the tire and wait for it to settle. The heaviest point will always settle at the bottom. I take a wax stick or marker and mark the top most point.
2. I then spin it again 2 more times to make sure it constantly settles in the correct place.
3. I will the usually take 2 weights (1/4oz in my case) and BLUE TAPE THEM to the rim. (DO NOT ADHERE THE WEIGHTS YET INCASE YOU ADD TO MANY)
4. You then turn the top point (with the weights) 90° to the left or right (doesnt matter). Let it go and see if it moves.
- If the weights move lower towards the bottom than you added to much.
-If the weights moved towards the top then it's not enough weight.
5. You repeat the process as add another weight until you can move the the wheel in any and all positions without it moving out of place.
That's when you know the the tire is perfectly balanced because there is no heavy spot trying to shift to a lower point of gravity.
6. When you figure out how many weights was perfect you can then take them off the tape, remove the double sided tape plastic from the back of the weights. And adhere them perfectly center to that top mark you made previously.
***Its very important to center the line of weights to that mark you made at the top (the lightest point) to replicate your results without variation. So that when you go to finally adhere the weights in place it's still perfectly balanced.
I have a spare cb1100 front wheel, I'd be happy to make a write up with pictures for you guys I'd you deem necessary
Thanks for that Mvk24 Thumbs Up
If you want to do a write-up and pictorial, that would be a great addition in the How-To section of the forum.
(06-26-2020, 02:30 AM)Lord Popgun_imp Wrote: Thanks for that Mvk24 Thumbs Up
How do you insert photos between paragraphs instead of all of them at the bottom?
Before you click the button that says insert into text, click on the line where you want to insert it, and with the cursor flashing there, click the insert button.
Or if you want to edit it after it was posted, you can copy the text and paste it in the appropriate area.
(06-26-2020, 04:38 AM)pekingduck_imp Wrote: Before you click the button that says insert into text, click on the line where you want to insert it, and with the cursor flashing there, click the insert button.
Thank you !
  FOund on Ebay- pretty good price on a used shop manual PowerDubs_imp 0 228 03-24-2023, 06:39 AM
  TRW brake rotors artashline_imp 8 649 02-02-2023, 05:44 AM
Last Post: CptMoustache_imp
  Warped rotors? DAC 39 2,362 06-10-2021, 03:28 AM
Last Post: jimgl3_imp
  Ebay radiator guard rattles... boynton6spd_imp 9 706 06-09-2021, 03:45 AM
Last Post: michael1954
  Brake Rotors 2017EX_imp 3 327 06-18-2020, 08:10 AM
  Front rotors, are they “floating” ? mattmcuomo@yahoo.com 4 391 05-02-2018, 11:04 AM
  2013 Shop Manual on eBay kennyw 2 282 08-28-2015, 12:36 AM
Last Post: DGShannon_imp
