Front rotors, are they “floating” ?
Do they float or not? It looks like they are bolted solid to the rim. Is that the “floating” mechanism bolted to the rim? (2014 Standard)
(04-27-2018, 02:52 AM)MMC_imp Wrote: Do they float or not? It looks like they are bolted solid to the rim. Is that the “floating” mechanism bolted to the rim? (2014 Standard)
There may be some spring to the cup washers under the T30 bolt heads
Ha. Yep. I just found that online. It shows that the bolt is in a “collar” and behind that is a spring with a washer between the rotor and rim too
Yeah, but it depends on your definition of a "floating" brake disc. To racers this means a set up where the disc mounting bolts have the ability to slide outward when the rotor expands due to massive heat build up. This prevents a warped disc or pulsation under braking. True "floating" discs will have slots with sliders in the place of the bolt holes found on most motorcycle or high performance car discs. Only really necessary under extreme racing conditions in my opinion.
I had replaced brake pads with some not so good ones, they made a lot of build up on rotors for one and that along with lots of highway dirt and grime built up in the “floating system “. I removed the rotors to clean out the “floating” parts. I put good EBC sintered pads and cleaned the sh!t out of everything.
Big improvement.
  TRW brake rotors artashline_imp 8 686 02-02-2023, 05:44 AM
Last Post: CptMoustache_imp
  Warped rotors? DAC 39 2,464 06-10-2021, 03:28 AM
Last Post: jimgl3_imp
  145$ for the set of rotors on ebay. mvk24_imp 37 2,857 06-26-2020, 10:11 AM
  Brake Rotors 2017EX_imp 3 338 06-18-2020, 08:10 AM
