01-30-2023, 09:50 AM
Has anyone used TRW rotors? I think I'm going to buy some.
TRW brake rotors
01-30-2023, 09:59 AM
A quick search finds no other mention of them.
01-30-2023, 10:47 AM
If I recall correctly, some members used TRW ...
http://cb1100forum.com/forum/showthread....ont+rotors
01-30-2023, 11:01 AM
PB is correct. I even wrote the part numbers down somewhere…
Maybe in that thread. I don’t feel like re-reading it
01-30-2023, 12:04 PM
02-01-2023, 02:18 AM
I've used them on a previous bike and had no problems whatsoever.
I found build quality to be easily a match for OEM stuff. Much cheaper than the alternative Brembo rotors that I also considered. I wouldn't hesistate to use TRW rotors again if the need ever came up. JT
02-01-2023, 04:19 AM
I've used these two as a replacement for a pair that became warped from a bad tire change. They work perfectly. indistinguishable from OEM.
02-01-2023, 08:03 AM
(02-01-2023, 02:18 AM)Jonnyteabag_imp Wrote: I've used them on a previous bike and had no problems whatsoever.thank you (02-01-2023, 04:19 AM)misterprofessionality_imp Wrote: I've used these two as a replacement for a pair that became warped from a bad tire change. They work perfectly. indistinguishable from OEM. thank you
02-02-2023, 05:44 AM
I have TRW brake pads on both bikes. Works as good as OEM.
« Next Oldest | Next Newest »
| Warped rotors? | DAC | 39 | 1,445 |
06-10-2021, 03:28 AM Last Post: jimgl3_imp |
| 145$ for the set of rotors on ebay. | mvk24_imp | 37 | 1,879 |
06-26-2020, 10:11 AM Last Post: mvk24_imp |
| Brake Rotors | 2017EX_imp | 3 | 233 |
06-18-2020, 08:10 AM Last Post: peterbaron |
| Bike fell over, broke the front brake lever and bent the rear brake | jlouis976_imp | 24 | 1,013 |
09-14-2018, 12:35 AM Last Post: Lord Popgun |
| Front rotors, are they “floating” ? | mattmcuomo@yahoo.com | 4 | 253 |
05-02-2018, 11:04 AM Last Post: mattmcuomo@yahoo.com |
| Front brake and brake light problem | Krupator_imp | 8 | 377 |
05-31-2016, 10:26 AM Last Post: Ulvetanna_imp |
| Brake light for front brake only? | meowguy_imp | 13 | 553 |
08-24-2013, 09:16 PM Last Post: meowguy_imp |
