Brake reservoir screw head issue
#31
(04-14-2022, 10:14 PM)Bazbro_imp Wrote: While we're on the subject...
Some of you may appreciate the information in this YouTube video...
https://youtu.be/dJfkCj3FWBs
Thumbs Up
(04-14-2022, 09:07 PM)Houtman_imp Wrote:
(04-14-2022, 01:43 PM)Cormanus_imp Wrote: Says the man who just sold 3 of them. Is it true, John, that they went because you couldn’t get the screws out of the reservoirs?
satchit, the same thing happened to me. I used an easy out, but I wish I’d some of these other tricks to try first.
No George , I did not sell them because of the screws in the reservoirs , I sold them because loss of tire pressure......
ROFL
Well, I tried multiple options...
Removed the other screw and tried wiggling the cover - No movement.
Tried the rubber band - Gouged out more.
Tried hammering in a slotted screwdriver and twisting - It looked like the small screwdriver would break.
I took it to a local bike shop here (incidentally the same guys who last bled the brakes in 2018). The mechanic wasn't confident he could drill it without damaging the threads. The suggestion was to get a replacement reservoir just in case this one gets damaged.
Does anyone know if either 45510-MGH-641 or 45510-MGH-305 would work? Revzilla says that 305 won't fit a 2014. I'm hoping I can find a used assembly.
The said screw extractor bit suggestion not tried?
http://cb1100forum.com/forum/showthread....#pid317168
(04-16-2022, 05:49 AM)GoldOxide_imp Wrote: The said screw extractor bit suggestion not tried?
Not yet. Will try and get a spare reservoir first. The mechanic was worried that the extractor may damage the threads.
I would still FIRST try the left handed screw removal tool before spending money on a new/used reservoir , start with the smallest first and than go up if needed . The set will come handy for other screwy problems.
OK, kinda late to the party, but people have had good luck with with a fine grit on the head of the driver. Valve grinding compound. Some toothpastes. Bigger the screw head, coarser the grit you can use.
Scraping some grit off a 400 sandpaper may be a better choice for you in your case.
The sharp little rocks will lock in between the driver and the screw head.
Not sure what your mechanic was thinking about, but if you drill the head out you will not touch the threads. it will just take the top of the screw off and leave the shank in place which you remove after you take the reservoir top off.
(04-20-2022, 07:53 PM)lash_imp Wrote: Not sure what your mechanic was thinking about, but if you drill the head out you will not touch the threads. it will just take the top of the screw off and leave the shank in place which you remove after you take the reservoir top off.
^^ +1^^ standard repair in case like this...
http://cb1100forum.com/forum/showthread....#pid317180
  JIS screw drivers Ridem32_imp 26 1,550 06-12-2026, 06:56 PM
  Help from the hive mind: Intermittent Starter Issue (2017) JRD 10 492 01-30-2026, 02:16 PM
Last Post: JRD
  Shifting issue Cormanus 31 2,099 05-15-2024, 12:59 AM
  Sight Glass Screw Mickey Dublin_imp 16 1,435 11-22-2023, 08:25 AM
  Arrow Slip on issue - stock gasket didn’t fit Ddawg1144_imp 4 438 02-21-2023, 07:51 AM
  Fuel reserve display issue Banksy_imp 2 271 06-29-2022, 04:37 AM
  Chrome cylinder head cap Juancho76_imp 21 1,516 04-03-2022, 08:48 AM
Last Post: Juancho76_imp
  Mechanical issue and hello again RickNRoll53_imp 8 636 12-16-2021, 06:46 AM
  CB 900C Custom Spark Issue goatman64_imp 3 346 11-27-2021, 07:11 AM
  Cams, Compression, Head Work? boynton6spd_imp 12 843 08-08-2021, 02:27 AM
Last Post: old blue_imp
