Clutch Fluid
#31
Thanks again for all the help here. Took the plunge (pun intended) yesterday. Fluid was dark, but reservoir was pretty clean. Siphoned out enough of the old fluid, but not all to avoid the chance of air getting in. Attached Mity Vac to the bleeder, but due to the angle, had to keep a hold on the bleed hose there. Next time I'll make a 45 degree adapter and clamp the hose to the bleeder.
Gear changes seem a little smoother now.
(05-11-2023, 08:24 PM)Wagonpeddler_imp Wrote: Thanks again for all the help here. Took the plunge (pun intended) yesterday. Fluid was dark, but reservoir was pretty clean. Siphoned out enough of the old fluid, but not all to avoid the chance of air getting in. Attached Mity Vac to the bleeder, but due to the angle, had to keep a hold on the bleed hose there. Next time I'll make a 45 degree adapter and clamp the hose to the bleeder.
Awesome glad it went well for you too.
I just used the harbor freight/Pittsburg steel hand pump bleeder with the 45° angle but it didn't seem like it was a great fit so I had to hold it on also.
(05-08-2023, 12:39 AM)Nachodaddy_imp Wrote:
(05-07-2023, 11:34 PM)mvk24_imp Wrote: Does anyone have a photo of where the bleeder/clutch slave cylinder is? The write up sais to remove the shink linkage from the plastic side cover but the shift linkage goes to metal cover and the plastic cover is up near the tank? I think im just reading something wrong but photos or videos make it alot easier for me to visualize.
That is not the plastic cover you seek. This video by Terrence O'Keeffe is fun to watch once you get past the painful music and intro. Should answer all your questions.
https://www.youtube.com/watch?v=keafupG_d6s
Beer
Beer
Great Video. However, he forgot the fork oil change process. Outside of installing new shims, it’s a probably one of the mire intensive processes, especially if you have to replace the fork seals.
  CLUTCH FLUID CHANGE SUPERCRUZ_imp 15 1,308 12-24-2025, 11:14 AM
  Replace clutch Lever Davidjill_imp 10 1,000 02-06-2025, 01:27 AM
  Clutch Plates finally going? misterprofessionality 12 1,084 11-22-2024, 07:49 AM
  Brake fluid flush CB1100@2013: photos valkyrie_rider_imp 0 256 02-13-2024, 10:28 AM
Last Post: valkyrie_rider_imp
  Clutch fluid change CB1100@2013: photos valkyrie_rider_imp 0 249 02-13-2024, 10:27 AM
  Clutch Not Working Henrik_imp 7 659 04-24-2023, 06:43 PM
Last Post: Henrik_imp
  Clutch pull mpuhl_imp 4 517 02-21-2023, 10:48 AM
  Synthetic Brake Fluid Wagonpeddler_imp 3 383 02-18-2023, 07:49 AM
  Clutch slave cylinder gasket Maturecheese_imp 3 399 01-27-2023, 12:33 AM
Last Post: Maturecheese_imp
  brake & clutch adjusters The Gecko_imp 10 871 11-25-2022, 08:47 AM
