Fork seals leaking @19,000 miles on ODO
#31
Ah, so he is “Bong” of the Lord’s Wine Cellar! ROFL
(03-16-2019, 11:39 PM)Frulk_imp Wrote: I bought the Sealmate per Flynrider at a local bike shop. Last one they had for $9.99. Sat on my driveway with the bike on centerstand and gently pried the dust covers up and out of the way and used the Sealmate as per instructions. I could almost swear I pulled out what appeared to be two grains of sand on the leaking fork. Pumped the forks a few times and put the dust covers back down snug. Was busy riding the Guzzi and XR yesterday so will run to my buddies coffee shop this AM on the CB and see if it did the trick. I’ll report back.
Good news indeed!
I’ve been appointed Cellarmaster to Milor’ Popgun. A new avatar seemed in order.
(03-21-2019, 12:43 PM)Cormanus_imp Wrote: I’ve been appointed Cellarmaster to Milor’ Popgun. A new avatar seemed in order.
I like it...make sure you won't drop any glass bottle...Tongue
I managed to clean/fix a leaking seal at the fork with a thin feeler gauge.
Update: It's been almost 20 days since I used the Sealmate to clean the forks seals. No recurring leaks to date. Appears that was the fix. Thumbs Up
Great.
Excellent Frulk.
(04-05-2019, 09:35 AM)Frulk_imp Wrote: Update: It's been almost 20 days since I used the Sealmate to clean the forks seals. No recurring leaks to date. Appears that was the fix. Thumbs Up
welll...how about that Thumbs Up
Glad to hear it worked out for you. Cleaning the seals is a pretty cheap alternative to replacement. Ever since I started using the Sealmate, I've wondered how many people have spent the bucks to replace the seals when a good cleaning would have sufficed.
  Oil pan leaking George050994_imp 26 1,917 08-17-2023, 09:34 PM
  Two different fork seals part numbers? misterprofessionality 3 396 08-18-2021, 01:55 PM
  fork overhaul vs. fork replacement? misterprofessionality 20 1,681 09-20-2020, 07:13 PM
Last Post: DBM_imp
  Gas leaking from overflow tubes Edtheguy_imp 11 776 09-01-2020, 02:35 AM
  Leaking fork seals Tezza_imp 33 2,091 08-04-2020, 10:34 PM
  Help with Master cylinder seals any help please dsan1964_imp 10 657 10-30-2018, 11:32 AM
Last Post: dsan1964_imp
  need help quick - oil leaking DJS_imp 32 1,830 08-24-2016, 02:04 AM
Last Post: Riko_imp
  slowly leaking - wondering if I own a lemon CB1100 Riko_imp 10 692 06-21-2016, 03:37 AM
Last Post: Riko_imp
  Leaking Fork Seal? linuxology_imp 16 1,097 05-03-2016, 01:08 AM
Last Post: aschem_imp
  Oil Change 2700 miles CIP57_imp 48 3,445 08-15-2014, 10:41 PM
Last Post: Pterodactyl_imp
