Valve Adjustment Intervals
#31
ROFL.. only by 0.01 mm
(04-17-2025, 10:48 AM)Whoops_imp Wrote:
(04-17-2025, 07:31 AM)Jurlie_imp Wrote:
(04-10-2025, 07:37 AM)balkanhound_imp Wrote: With 10k on my 2017 looks like I will be doing the valve ck at 12k. I'm assuming it will probably close to spec with no adjustment necessary as with most of my later model Hondas. Has anybody found their valves needing adjustment at 12k?
I check/adjust my valves every 24k after initial 12k check when the dealer told me all was in spec. At 24k miles I typically have several valves on the boundary or 0.01mm out of spec. So my checks were at 12k, 36k, 60k and next check is soon to be at 84k miles.
I think the valve checks are pushing your valves out of spec. Smile
yep, that explains why peterbaron and others who don’t ever check them have no issues in the long run
(04-21-2025, 07:51 AM)m in sc_imp Wrote: .01mm (.0003") is literally 1/10th a sheet of paper. I mean i can get super picky about adjustments but really, thats nothing to be concerned about at all... assuming that comment was serious...which i hope it wasnt. Smile
No, I was kidding.
But on serious note, each time when i adjust valves, I set them as close to the specified value as shims make it possible (e. g. 0.28 and 0.15mm respectively), and they can have 0.03mm deviation, which means, some valves’ clearance may change by 0.03-0.04 on the course of 24k miles. That obviously doesn’t mean that progression is linear. It’s totally possible that once the valve sets on some value, it may change very little on a big course of time (miles) which would explain why guys who don’t adjust valves don’t have major issues
  Valve Adjustment Shims dave 13 707 07-28-2026, 12:49 PM
Last Post: MagnaRider
  Valve Adjustment and Camshaft Removal dave 5 631 03-21-2026, 04:49 PM
  Valve Adjustment dave 6 864 08-29-2025, 10:46 AM
  Valve Cover Baffle lining ? bflint 6 944 07-26-2025, 11:27 AM
Last Post: bflint
  Rear Brake Pedal Adjustment Gone in 60 12 1,145 04-04-2024, 08:18 AM
  Valve Adjustment Tolerances - How Far Do You Go? dave 14 1,512 10-18-2023, 09:28 PM
Last Post: The Gecko_imp
  Observed Valve Clearance Cormanus 16 1,450 03-06-2023, 09:03 AM
Last Post: Tejas_imp
  The OBSERVED Valve Clearance thread Pterodactyl_imp 162 12,729 12-27-2022, 08:35 AM
  Checking valve clearances Maturecheese_imp 74 6,521 12-11-2022, 12:56 PM
  Valve noise (i think) Maturecheese_imp 6 646 07-08-2022, 03:41 AM
Last Post: 1973cb750
