Turn Signal Swap - Blown Fuses
Kodeman_imp Offline
New to the Forum
Threads: 0
RE: Turn Signal Swap - Blown Fuses
(06-20-2018, 05:12 AM)12milesout_imp Wrote:
(07-27-2014, 06:34 AM)Razor_imp Wrote: If your connections are tight and insulated; I'd look to make sure you have the wiring connected as follows.
Left, Orange wire = 12v
Green = ground
Right, Light Blue wire = 12v
Green = ground
I'm guessing one side is correct, while the other is backwards. Each time the turn signal is enabled, the 12v feed goes to ground, causing the short.
Good luck, let us what you find.
(07-27-2014, 10:17 AM)Elipten_imp Wrote: Just some more info. I was wiring on my 2014 Dlx yesterday installing aux LED lighting. I found there is a flaw in my bikes wiring for the rear turn signals. The lt blue and orange wires are the ground wires and the ground wires are actually the power wires. Completely opposite my 2013 std. Took me hours of trouble shooting and I double checked the wiring diagram. Thank you very much Honda for piss poor QAQC. I sweated in the Texas heat checking everything until the improbable became the probable.
I ran into the same issue when wiring some motoGadget M-blaze LED's on my 2014 standard; the wiring in the rear was reversed (greens were hot, blue/orange were ground), but up front the greens were ground. Glad I had seen these posts prior to pulling things apart.
Ill have to test that out and see if thats the issue! Thank you!
06-20-2018, 08:16 AM
Threads: 346
Likes Given: 963
Any further discussion on Kodeman’s question should occur http://cb1100forum.com/forum/showthread.php?tid=12779 please.
06-20-2018, 07:37 PM
  wheel swap cad cnc lazer reluctor for speed sensor 1973cb750 13 3,041 10-28-2025, 05:56 AM
Last Post: 1973cb750
  Turn Signal Indicators balkanhound_imp 5 642 04-17-2025, 11:17 PM
  2014 CB1100 Clear Turn Signal Lenses Ngavrielidis1_imp 16 1,448 04-15-2025, 06:23 AM
Last Post: Ngavrielidis1_imp
  Smaller turn signal/running light choices TxRonHarris_imp 33 2,393 07-06-2021, 10:00 PM
  Extra turn signal on dash Mixagon_imp 7 719 06-24-2021, 07:20 AM
Last Post: 17-CB-002
  Turn Signal Relocation Cormanus 11 847 12-30-2020, 11:12 AM
  best sprocket swap for city commuter acceleration... boynton6spd_imp 3 334 12-04-2020, 12:35 PM
  Wire Wheel / Cast Wheel Swap pekingduck 37 2,476 06-05-2020, 12:35 PM
Last Post: michael1954
  Signal Relocation Ben70_imp 7 737 02-20-2020, 10:22 AM
Last Post: Ben70_imp
  Turn signal relocation -- Making room for my backseat rider JMA_imp 13 961 06-15-2019, 12:44 PM
Last Post: QUINTtastic_imp
