Extra turn signal on dash
Mixagon_imp Offline
Threads: 35
Not sure how you feel about the turn signal lights on the CB dash, I think they are very poor as are most bikes I've owned except the Yam FJR.
I came up with this home made solution years ago and have moved this onto most bikes I've owned to stop me leaving the turn signal on or keep pressing the button to check they are really off.
So I installed it on the CB today.
Hope this short video works ok and shows how you can see it even if not looking at it and it even reflects in the screen so doubles the effect.
https://btcloud.bt.com/web/app/share/invite/40CazLgoup
The one light works on left and right signals so just one is needed and if its to bright at night or not needed I just stick black tape over it.
06-22-2021, 04:13 AM
RE: Extra turn signal on dash
Hmm, cool - not bad.
06-22-2021, 04:19 AM
Mixagon_imp Offline
Threads: 35
(06-22-2021, 04:19 AM)GoldOxide_imp Wrote: Hmm, cool - not bad.
Gave it the road test today and its in the perfect position to see if my turn signal is on in my lower vision while looking at the road ahead even in bright sunlight so no need to keep looking down or pressing the turn button to check.
Makes for safer riding with one risk less. What started me off on this route was years ago seeing a rider with his forgotten turn signal on and a car pulled out and knocked him off Sad
06-23-2021, 01:15 AM
Gone in 60 Offline
Blood Biker of the Apocalypse
Orange County, CA
Threads: 245
Likes Received: 1,196 in 513 posts
Likes Given: 972
Not a bad idea! I say that as someone who pulled up to my office door this morning and saw the reflection of my right signal blinking... hopefully I left it on from turning into the parking lot, and not way back when I was getting off the freeway.
06-23-2021, 06:53 AM
17-CB-002 Offline
Threads: 45
(06-22-2021, 04:13 AM)Mixagon_imp Wrote: Not sure how you feel about the turn signal lights on the CB dash, I think they are very poor as are most bikes I've owned except the Yam FJR.
Great mind thinks alike
Looked like we had the same idea, however, I only used 1 LED. See my additional turn signal set up using this link. Post #367
http://cb1100forum.com/forum/showthread....8&page=764
06-24-2021, 06:00 AM
peterbaron Offline
Likes Given: 996
I can DOT/certify Alain's after today 200 mile ride
Biker
P.S. Mixagon, if you want yours to be DOT certified, you have to come to Canada...a.s.a they open that bridge Tongue
06-24-2021, 06:04 AM
Tev62 Offline
Threads: 33
Likes Given: 95
If you don't want to make your own try one of these https://www.bikevis.com/product/motorcyc...-reminder/ There seems to be a few people making this type of product.
06-24-2021, 06:06 AM
17-CB-002 Offline
Threads: 45
If anyone is interested here's the electrical drawings.
Note: I wanted to avoid the front turn signals due to the running light function, so I tap into the rear turn signal wires.
The diodes and LED light can be purchased from any local electronic place.
I also noticed that HONDA is using a "Clutch Diode" in the fuse box, may be that one can also be used (very compact - looks like a fuse however, it is a 3-prong).
One can get the diode from a motorcycle recycler.
Good Luck
06-24-2021, 07:20 AM
  Turn Signal Indicators balkanhound_imp 5 698 04-17-2025, 11:17 PM
  2014 CB1100 Clear Turn Signal Lenses Ngavrielidis1_imp 16 1,520 04-15-2025, 06:23 AM
Last Post: Ngavrielidis1_imp
  Thinkware M1 vs Innovv K5 or K7 dual dash cams ? Davidjill_imp 2 409 02-06-2025, 03:07 AM
Last Post: Davidjill_imp
  Smaller turn signal/running light choices TxRonHarris_imp 33 2,624 07-06-2021, 10:00 PM
  Turn Signal Relocation Cormanus 11 910 12-30-2020, 11:12 AM
  Signal Relocation Ben70_imp 7 763 02-20-2020, 10:22 AM
Last Post: Ben70_imp
  Turn signal relocation -- Making room for my backseat rider JMA_imp 13 1,027 06-15-2019, 12:44 PM
Last Post: QUINTtastic_imp
  Where to tap speed sensor signal? egleaves_imp 93 5,440 10-19-2018, 08:49 AM
  Turn Signal Swap - Blown Fuses grover_imp 21 1,298 06-20-2018, 07:37 PM
  Fast flashing turn signal cafe74_imp 9 722 05-27-2017, 04:13 PM
Last Post: CSODenmark_imp
