best sprocket swap for city commuter acceleration...
boynton6spd_imp Offline
Threads: 8
limited highway use
12-02-2020, 04:26 AM
LakeWylieJoe_imp Offline
Threads: 11
RE: best sprocket swap for city commuter acceleration...
It would seem the only reasons to change the overall gearing of the bike via a sprocket swap is if first gear is too tall, or if sixth has you turning too many revs on the highway. Otherwise, you simply select a higher or lower gear for the given conditions.
If first gear is too tall for you, you'd look for a smaller front sprocket (which is pretty small to begin with--there is probably a minimum recommended number of teeth up front for a 530 chain) or a larger rear one, which may require a longer chain.
I'm sure several owners have done the swap and can chime in.
12-02-2020, 08:19 AM
Likes Given: 1,010
http://cb1100forum.com/forum/search.php?...order=desc
12-02-2020, 08:24 AM
17-CB-002 Offline
Threads: 45
Try this site courtesy from Big Sheep
http://cb1100forum.com/forum/showthread.php?tid=16247
12-04-2020, 12:35 PM
  wheel swap cad cnc lazer reluctor for speed sensor 1973cb750 13 3,143 10-28-2025, 05:56 AM
Last Post: 1973cb750
  Wire Wheel / Cast Wheel Swap pekingduck 37 2,532 06-05-2020, 12:35 PM
Last Post: michael1954
  Rear Sprocket Nuts 89gaz89_imp 3 356 05-02-2020, 07:35 AM
  19 tooth countershaft sprocket physics-teacher_imp 19 1,434 12-13-2019, 09:41 PM
Last Post: marel_imp
  Smaller rear sprocket? DBM_imp 11 925 08-14-2019, 10:50 AM
Last Post: jimgl3_imp
  tank swap nckcrdn_imp 4 517 03-14-2019, 12:18 PM
  City Scrambler/ Touring Modz cb1100_dude_imp 17 1,217 02-26-2019, 03:49 AM
Last Post: jitaylor_imp
  Front suspension swap DBM_imp 2 382 01-29-2019, 08:07 PM
Last Post: chync_imp
  Turn Signal Swap - Blown Fuses grover_imp 21 1,294 06-20-2018, 07:37 PM
  Who also installed these clubman handlebars from Dime City Cycles? chync_imp 4 423 03-25-2018, 08:11 AM
